All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Searching...
No Matches
Lazy_toplex_map.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author: François Godi, Vincent Rouvreau
4 *
5 * Copyright (C) 2018 INRIA
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef LAZY_TOPLEX_MAP_H
12#define LAZY_TOPLEX_MAP_H
13
14#include <gudhi/Toplex_map.h>
15#include <boost/heap/fibonacci_heap.hpp>
16
17namespace Gudhi {
18
27 public:
30
33
36
39
42 template <typename Input_vertex_range>
43 void insert_independent_simplex(const Input_vertex_range &vertex_range);
44
47 template <typename Input_vertex_range>
48 bool insert_simplex(const Input_vertex_range &vertex_range);
49
52 template <typename Input_vertex_range>
53 void remove_simplex(const Input_vertex_range &vertex_range);
54
56 template <typename Input_vertex_range>
57 bool membership(const Input_vertex_range &vertex_range);
58
60 template <typename Input_vertex_range>
61 bool all_facets_inside(const Input_vertex_range &vertex_range);
62
66 Vertex contraction(const Vertex x, const Vertex y);
67
69 std::size_t num_maximal_simplices() const { return size; }
70
72 std::size_t num_vertices() const { return t0.size(); }
73
74 private:
75 template <typename Input_vertex_range>
76 void erase_max(const Input_vertex_range &vertex_range);
77 template <typename Input_vertex_range>
78 Vertex best_index(const Input_vertex_range &vertex_range);
79 void clean(const Vertex v);
80
81 std::unordered_map<Vertex, std::size_t> gamma0_lbounds;
82
83 std::unordered_map<Vertex, Simplex_ptr_set> t0;
84 bool empty_toplex = true; // Is the empty simplex a toplex ?
85
86 typedef boost::heap::fibonacci_heap<std::pair<std::size_t, Vertex>> PriorityQueue;
87 PriorityQueue cleaning_priority;
88 std::unordered_map<Vertex, PriorityQueue::handle_type> cp_handles;
89
90 std::size_t get_gamma0_lbound(const Vertex v) const;
91
92 std::size_t size_lbound = 0;
93 std::size_t size = 0;
94
95 const double ALPHA = 4; // time
96 const double BETTA = 8; // memory
97};
98
99template <typename Input_vertex_range>
100void Lazy_toplex_map::insert_independent_simplex(const Input_vertex_range &vertex_range) {
101 for (const Vertex &v : vertex_range)
102 if (!gamma0_lbounds.count(v))
103 gamma0_lbounds.emplace(v, 1);
104 else
105 gamma0_lbounds[v]++;
106 size_lbound++;
107 insert_simplex(vertex_range);
108}
109
110template <typename Input_vertex_range>
111bool Lazy_toplex_map::insert_simplex(const Input_vertex_range &vertex_range) {
112 Simplex sigma(vertex_range.begin(), vertex_range.end());
113 // Check empty face management
114 empty_toplex = (sigma.size() == 0);
115 Simplex_ptr sptr = std::make_shared<Simplex>(sigma);
116 bool inserted = false;
117 for (const Vertex &v : sigma) {
118 if (!t0.count(v)) {
119 t0.emplace(v, Simplex_ptr_set());
120 auto v_handle = cleaning_priority.push(std::make_pair(0, v));
121 cp_handles.emplace(v, v_handle);
122 }
123 inserted = t0.at(v).emplace(sptr).second;
124 cleaning_priority.update(cp_handles.at(v), std::make_pair(t0.at(v).size() - get_gamma0_lbound(v), v));
125 }
126 if (inserted) size++;
127 if (size > (size_lbound + 1) * BETTA) clean(cleaning_priority.top().second);
128 return inserted;
129}
130
131template <typename Input_vertex_range>
132void Lazy_toplex_map::remove_simplex(const Input_vertex_range &vertex_range) {
133 if (vertex_range.begin() == vertex_range.end()) {
134 t0.clear();
135 gamma0_lbounds.clear();
136 cleaning_priority.clear();
137 size_lbound = 0;
138 size = 0;
139 empty_toplex = false;
140 } else {
141 const Vertex &v = best_index(vertex_range);
142 // Copy constructor needed because the set is modified
143 if (t0.count(v))
144 for (const Simplex_ptr &sptr : Simplex_ptr_set(t0.at(v)))
145 if (included(vertex_range, *sptr)) {
146 erase_max(*sptr);
147 for (const Simplex &f : facets(vertex_range)) insert_independent_simplex(f);
148 }
149 }
150}
151
152template <typename Input_vertex_range>
153bool Lazy_toplex_map::membership(const Input_vertex_range &vertex_range) {
154 if (t0.size() == 0 && !empty_toplex) return false; // empty complex
155 if (vertex_range.begin() == vertex_range.end()) return true; // empty query simplex
156 Vertex v = best_index(vertex_range);
157 if (!t0.count(v)) return false;
158 for (const Simplex_ptr &sptr : t0.at(v))
159 if (included(vertex_range, *sptr)) return true;
160 return false;
161}
162
163template <typename Input_vertex_range>
164bool Lazy_toplex_map::all_facets_inside(const Input_vertex_range &vertex_range) {
165 Simplex sigma(vertex_range.begin(), vertex_range.end());
166 Vertex v = best_index(sigma);
167 if (!t0.count(v)) return false;
168 Simplex f = sigma;
169 f.erase(v);
170 if (!membership(f)) return false;
171 std::unordered_set<Vertex> facets_inside;
172 for (const Simplex_ptr &sptr : t0.at(v))
173 for (const Vertex &w : sigma) {
174 f = sigma;
175 f.erase(w);
176 if (included(f, *sptr)) facets_inside.insert(w);
177 }
178 return facets_inside.size() == sigma.size() - 1;
179}
180
181/* Returns the remaining vertex */
183 if (!t0.count(x)) return y;
184 if (!t0.count(y)) return x;
185 Vertex k, d;
186 if (t0.at(x).size() > t0.at(y).size())
187 k = x, d = y;
188 else
189 k = y, d = x;
190 // Copy constructor needed because the set is modified
191 for (const Simplex_ptr &sptr : Simplex_ptr_set(t0.at(d))) {
192 Simplex sigma(*sptr);
193 erase_max(sigma);
194 sigma.erase(d);
195 sigma.insert(k);
196 insert_simplex(sigma);
197 }
198 t0.erase(d);
199 return k;
200}
201
202/* No facets insert_simplexed */
203template <typename Input_vertex_range>
204inline void Lazy_toplex_map::erase_max(const Input_vertex_range &vertex_range) {
205 Simplex sigma(vertex_range.begin(), vertex_range.end());
206 empty_toplex = false;
207 Simplex_ptr sptr = std::make_shared<Simplex>(sigma);
208 bool erased = false;
209 for (const Vertex &v : sigma) {
210 erased = t0.at(v).erase(sptr) > 0;
211 if (t0.at(v).size() == 0) t0.erase(v);
212 }
213 if (erased) size--;
214}
215
216template <typename Input_vertex_range>
217Lazy_toplex_map::Vertex Lazy_toplex_map::best_index(const Input_vertex_range &vertex_range) {
218 Simplex tau(vertex_range.begin(), vertex_range.end());
219 std::size_t min = std::numeric_limits<size_t>::max();
220 Vertex arg_min = -1;
221 for (const Vertex &v : tau)
222 if (!t0.count(v))
223 return v;
224 else if (t0.at(v).size() < min)
225 min = t0.at(v).size(), arg_min = v;
226 if (min > ALPHA * get_gamma0_lbound(arg_min)) clean(arg_min);
227 return arg_min;
228}
229
230std::size_t Lazy_toplex_map::get_gamma0_lbound(const Vertex v) const {
231 return gamma0_lbounds.count(v) ? gamma0_lbounds.at(v) : 0;
232}
233
234void Lazy_toplex_map::clean(const Vertex v) {
235 Toplex_map toplices;
236 std::unordered_map<int, std::vector<Simplex>> dsorted_simplices;
237 std::size_t max_dim = 0;
238 for (const Simplex_ptr &sptr : Simplex_ptr_set(t0.at(v))) {
239 if (sptr->size() > max_dim) {
240 for (std::size_t d = max_dim + 1; d <= sptr->size(); d++) dsorted_simplices.emplace(d, std::vector<Simplex>());
241 max_dim = sptr->size();
242 }
243 dsorted_simplices[sptr->size()].emplace_back(*sptr);
244 erase_max(*sptr);
245 }
246 for (std::size_t d = max_dim; d >= 1; d--)
247 for (const Simplex &s : dsorted_simplices.at(d))
248 if (!toplices.membership(s)) toplices.insert_independent_simplex(s);
249 Simplex sv;
250 sv.insert(v);
251 auto clean_cofaces = toplices.maximal_cofaces(sv);
252 size_lbound = size_lbound - get_gamma0_lbound(v) + clean_cofaces.size();
253 gamma0_lbounds[v] = clean_cofaces.size();
254 for (const Simplex_ptr &sptr : clean_cofaces) insert_simplex(*sptr);
255}
256
257} // namespace Gudhi
258
259#endif /* LAZY_TOPLEX_MAP_H */
Lazy toplex map data structure for representing unfiltered simplicial complexes.
Definition: Lazy_toplex_map.h:26
Toplex_map::Vertex Vertex
Definition: Lazy_toplex_map.h:29
Adds the given simplex to the complex. Nothing happens if the simplex is already in the complex (i....
Definition: Lazy_toplex_map.h:111
Toplex_map::Simplex_ptr Simplex_ptr
Definition: Lazy_toplex_map.h:35
Number of maximal simplices.
Definition: Lazy_toplex_map.h:69
Toplex_map::Simplex Simplex
Definition: Lazy_toplex_map.h:32
Removes the given simplex and its cofaces from the complex. Its faces are kept inside.
Definition: Lazy_toplex_map.h:132
Definition: Lazy_toplex_map.h:153
Definition: Lazy_toplex_map.h:100
Definition: Lazy_toplex_map.h:164
Number of vertices.
Definition: Lazy_toplex_map.h:72
Definition: Lazy_toplex_map.h:182
Toplex_map::Simplex_ptr_set Simplex_ptr_set
Definition: Lazy_toplex_map.h:38
std::unordered_set< Toplex_map::Simplex_ptr, Sptr_hash, Sptr_equal > Simplex_ptr_set
Definition: Toplex_map.h:49
std::shared_ptr< Toplex_map::Simplex > Simplex_ptr
Definition: Toplex_map.h:38
std::set< Vertex > Simplex
Definition: Toplex_map.h:35
std::size_t Vertex
Definition: Toplex_map.h:32
