A class that encodes the function, the zero-set of which is a surface of revolution around the x axis based on the lemniscate of Bernoulli embedded in R^3.
 More...
#include <include/gudhi/Functions/Function_lemniscate_revolution_in_R3.h>
| Eigen::VectorXd  | operator() (const Eigen::VectorXd &p) const |
|   | Value of the function at a specified point.  More...
std::size_t  | amb_d () const |
|   | Returns the (ambient) domain dimension.
std::size_t  | cod_d () const |
|   | Returns the codomain dimension.
Eigen::VectorXd  | seed () const |
|   | Returns a point on the surface. This seed point is only one of two necessary seed points for the manifold tracing algorithm. See the method seed2() for the other point.
Eigen::VectorXd  | seed2 () const |
|   | Returns a point on the surface. This seed point is only one of two necessary seed points for the manifold tracing algorithm. See the method seed() for the other point.
|   | Function_lemniscate_revolution_in_R3 (double a=1, Eigen::Vector3d off=Eigen::Vector3d::Zero()) |
|   | Constructor of the function that defines a surface of revolution around the x axis based on the lemniscate of Bernoulli embedded in R^3.  More...
◆ Function_lemniscate_revolution_in_R3()
          | Gudhi::coxeter_triangulation::Function_lemniscate_revolution_in_R3::Function_lemniscate_revolution_in_R3  |
          double  |
          a = 1,  |
          Eigen::Vector3d  |
          off = Eigen::Vector3d::Zero()  |
inline   |
- Parameters
    | [in] | a | A numerical parameter.  |
    | [in] | off | Offset vector.  |
◆ operator()()
          | Eigen::VectorXd Gudhi::coxeter_triangulation::Function_lemniscate_revolution_in_R3::operator()  |
          const Eigen::VectorXd &  |
          p | ) |
           const |
inline   |
- Parameters
    | [in] | p | The input point. The dimension needs to coincide with the ambient dimension.  |
The documentation for this class was generated from the following file:
