The concept SimplicialComplexForAlpha3d describes the requirements for a type to implement a simplicial complex, that can be created from a Alpha_complex_3d.
 More...
#include <concept/Alpha_complex/SimplicialComplexForAlpha3d.h>
Public Types | |
| typedef unspecified | Vertex_handle |
| typedef unspecified | Filtration_value |
Public Member Functions | |
| std::size_t | num_vertices () |
| void | insert_simplex (std::vector< Vertex_handle > const &vertex_range, Filtration_value filtration) |
| Inserts a simplex from a given simplex (represented by a vector of Vertex_handle) in the simplicial complex with the given 'filtration' value.  | |
| void | make_filtration_non_decreasing () |
| void | prune_above_filtration (Filtration_value filtration) |
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha3d::Filtration_value |
Handle to specify the simplex filtration value.
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha3d::Vertex_handle |
Handle to specify a vertex. Must be a non-negative integer.
| void Gudhi::alpha_complex::SimplicialComplexForAlpha3d::make_filtration_non_decreasing | ( | ) |
Browses the simplicial complex to make the filtration non-decreasing.
| std::size_t Gudhi::alpha_complex::SimplicialComplexForAlpha3d::num_vertices | ( | ) |
Returns the number of vertices in the simplicial complex.
| void Gudhi::alpha_complex::SimplicialComplexForAlpha3d::prune_above_filtration | ( | Filtration_value | filtration | ) |
Prune the simplicial complex above 'filtration' value given as parameter.
