Cech complex class.
 More...
#include <include/gudhi/Cech_complex.h>
| template<typename InputPointRange >  |
|   | Cech_complex (const InputPointRange &points, Filtration_value max_radius, const bool exact=false) |
|   | Cech_complex constructor from a range of points.  More...
| void  | create_complex (SimplicialComplexForCechComplex &complex, int dim_max) |
|   | Initializes the simplicial complex from the proximity graph and expands it until a given maximal dimension, using the Cech blocker oracle.  More...
| Filtration_value  | max_radius () const |
| const Point_d &  | get_point (Vertex_handle vertex) const |
| std::vector< Sphere > &  | get_cache () |
| const bool  | is_exact () |
|   | Check exact option.  More...
template<typename Kernel, typename SimplicialComplexForCechComplex>
class Gudhi::cech_complex::Cech_complex< Kernel, SimplicialComplexForCechComplex >
Cech complex class.
Cech complex is a simplicial complex where the set of all simplices is filtered by the radius of their minimal enclosing ball and bounded by the given max_radius.
- Template Parameters
    | Kernel | CGAL kernel: either Epick_d or Epeck_d. |
    | SimplicialComplexForCechComplex | furnishes Vertex_handle and Filtration_value type definition required by Gudhi::Proximity_graph and Cech blocker.  |
- Examples
 - cech_complex_example_from_points.cpp, and cech_persistence.cpp.
◆ Cech_complex()
template<typename Kernel , typename SimplicialComplexForCechComplex >
          | Gudhi::cech_complex::Cech_complex< Kernel, SimplicialComplexForCechComplex >::Cech_complex  |
          const InputPointRange &  |
          points,  |
          Filtration_value  |
          max_radius,  |
          const bool  |
          exact = false  |
inline   |
- Parameters
    | [in] | points | Range of points where each point is defined as kernel::Point_d.  |
    | [in] | max_radius | Maximal radius value.  |
    | [in] | exact | Exact filtration values computation. Not exact if Kernel is not CGAL::Epeck_d. Default is false.  |
◆ create_complex()
- Parameters
- Exceptions
    | std::invalid_argument | In debug mode, if `complex.num_vertices()` does not return 0.  |
◆ get_cache()
- Returns
 - Vector of cached spheres.
◆ get_point()
- Parameters
    | [in] | vertex | Point position in the range.  |
- Returns
 - The point.
◆ is_exact()
Check exact option.
- Returns
 - Exact option.
◆ max_radius()
- Returns
 - max_radius value given at construction.
The documentation for this class was generated from the following file:
