Simple traits that is a model of SkeletonBlockerDS and can be passed as a template argument to Skeleton_blocker_complex. More...
#include <include/gudhi/Skeleton_blocker/Skeleton_blocker_simple_traits.h>
Classes | |
| struct | Root_vertex_handle |
| Global and local handle similar to boost subgraphs. Vertices are stored in a vector. For the root simplicial complex, the local and global descriptors are the same. For a subcomplex L and one of its vertices 'v', the local descriptor of 'v' is its position in the vertex vector of the subcomplex L whereas its global descriptor is the position of 'v' in the vertex vector of the root simplicial complex. More... | |
Additional Inherited Members | |
Public Types inherited from Gudhi::skeleton_blocker::SkeletonBlockerDS | |
| typedef int | boost_vertex_handle |
| index that allows to find the vertex in the boost graph | |
