A class that encodes the function, the zero-set of which is the Whitney umbrella surface embedded in R^3.
More...
#include <include/gudhi/Functions/Function_whitney_umbrella_in_R3.h>
| Eigen::VectorXd | operator() (const Eigen::VectorXd &p) const |
| | Value of the function at a specified point. More...
std::size_t | amb_d () const |
| | Returns the (ambient) domain dimension.
std::size_t | cod_d () const |
| | Returns the codomain dimension.
Eigen::VectorXd | seed () const |
| | Returns a point on the surface. This seed point is only one of two necessary seed points for the manifold tracing algorithm. See the method seed2() for the other point.
Eigen::VectorXd | seed2 () const |
| | Returns a point on the surface. This seed point is only one of two necessary seed points for the manifold tracing algorithm. See the method seed() for the other point.
| | Function_whitney_umbrella_in_R3 (Eigen::Vector3d off=Eigen::Vector3d::Zero()) |
| | Constructor of the function that defines the Whitney umbrella in R^3. More...
◆ Function_whitney_umbrella_in_R3()
| Gudhi::coxeter_triangulation::Function_whitney_umbrella_in_R3::Function_whitney_umbrella_in_R3 |
Eigen::Vector3d |
off = Eigen::Vector3d::Zero() | ) |
inline |
- Parameters
◆ operator()()
| Eigen::VectorXd Gudhi::coxeter_triangulation::Function_whitney_umbrella_in_R3::operator() |
const Eigen::VectorXd & |
p | ) |
const |
inline |
- Parameters
| [in] | p | The input point. The dimension needs to coincide with the ambient dimension. |
The documentation for this class was generated from the following file:
