Class that represents a geometric complex that can be simplified. The class allows access to points of vertices.
More...
| template<typename PointIterator > |
| | Skeleton_blocker_geometric_complex (int num_vertices, PointIterator begin, PointIterator end) |
| template<typename SimpleHandleOutputIterator , typename PointIterator > |
| | Skeleton_blocker_geometric_complex (SimpleHandleOutputIterator simplex_begin, SimpleHandleOutputIterator simplex_end, PointIterator points_begin, PointIterator points_end, bool is_flag_complex=false) |
| | Constructor with a list of simplices. More...
| template<typename SimpleHandleOutputIterator > |
| | Skeleton_blocker_geometric_complex (SimpleHandleOutputIterator simplex_begin, SimpleHandleOutputIterator simplex_end, bool is_flag_complex=false) |
| | Constructor with a list of simplices. Points of every vertex are the point constructed with default constructor. More...
Vertex_handle | add_vertex () |
| | Add a vertex to the complex with a default constructed associated point.
Vertex_handle | add_vertex (const Point &point) |
| | Add a vertex to the complex with its associated point.
const Point & | point (Vertex_handle v) const |
| | Returns the Point associated to the vertex v.
Point & | point (Vertex_handle v) |
| Geometric_link | link (Vertex_handle v) const |
| Geometric_link | link (const Simplex &simplex) const |
| Geometric_link | link (Edge_handle edge) const |
| Abstract_link | abstract_link (Vertex_handle v) const |
| Abstract_link | abstract_link (const Simplex &simplex) const |
| Abstract_link | abstract_link (Edge_handle edge) const |
| Vertex_handle | operator[] (Root_vertex_handle global) const |
| | Return a local Vertex_handle of a vertex given a global one. More...
| Graph_vertex & | operator[] (Vertex_handle address) |
| | Return the vertex node associated to local Vertex_handle. More...
| const Graph_vertex & | operator[] (Vertex_handle address) const |
| | Adds a vertex to the simplicial complex and returns its Vertex_handle. More...
| void | remove_vertex (Vertex_handle address) |
| | Remove a vertex from the simplicial complex. More...
bool | contains_vertex (Vertex_handle u) const |
bool | contains_vertex (Root_vertex_handle u) const |
| bool | contains_vertices (const Simplex &sigma) const |
| virtual boost::optional< Vertex_handle > | get_address (Root_vertex_handle id) const |
| | Given an Id return the address of the vertex having this Id in the complex. More...
| Root_vertex_handle | get_id (Vertex_handle local) const |
| Vertex_handle | convert_handle_from_another_complex (const Skeleton_blocker_complex &other, Vertex_handle vh_in_other) const |
| | Convert an address of a vertex of a complex to the address in the current complex. More...
int | degree (Vertex_handle local) const |
| | return the graph degree of a vertex.
boost::optional< Edge_handle > | operator[] (const std::pair< Vertex_handle, Vertex_handle > &ab) const |
| | return an edge handle if the two vertices forms an edge in the complex
Graph_edge & | operator[] (Edge_handle edge_handle) |
| | returns the stored node associated to an edge
const Graph_edge & | operator[] (Edge_handle edge_handle) const |
| Vertex_handle | first_vertex (Edge_handle edge_handle) const |
| | returns the first vertex of an edge More...
| Vertex_handle | second_vertex (Edge_handle edge_handle) const |
| Simplex | get_vertices (Edge_handle edge_handle) const |
| | returns the simplex made with the two vertices of the edge More...
| Edge_handle | add_edge (Vertex_handle a, Vertex_handle b) |
| | Adds an edge between vertices a and b. More...
void | add_edge (const Simplex &s) |
| | Adds all edges of s in the complex.
| Edge_handle | add_edge_without_blockers (Vertex_handle a, Vertex_handle b) |
| | Adds an edge between vertices a and b without blockers. More...
void | add_edge_without_blockers (Simplex s) |
| | Adds all edges of s in the complex without adding blockers.
| virtual Edge_handle | remove_edge (Vertex_handle a, Vertex_handle b) |
| | Removes an edge from the simplicial complex and all its cofaces. More...
void | remove_edge (Edge_handle edge) |
| | Removes edge and its cofaces from the simplicial complex.
void | keep_only_vertices () |
| | The complex is reduced to its set of vertices. All the edges and blockers are removed.
| bool | contains_edge (Vertex_handle a, Vertex_handle b) const |
| bool | contains_edges (const Simplex &sigma) const |
std::string | to_string () const |
std::string | vertices_to_string () const |
std::string | edges_to_string () const |
std::string | blockers_to_string () const |
| bool | is_popable_blocker (Blocker_handle sigma) const |
| void | remove_popable_blockers () |
| void | remove_popable_blockers (Vertex_handle v) |
| void | remove_all_popable_blockers (Vertex_handle v) |
| | Removes all the popable blockers of the complex passing through v and delete them. Also remove popable blockers in the neighborhood if they became popable. More...
| void | remove_star (Vertex_handle v) |
| void | remove_star (Vertex_handle a, Vertex_handle b) |
| void | remove_star (Edge_handle e) |
| void | remove_star (const Simplex &sigma) |
| void | add_simplex (const Simplex &sigma) |
| | add a simplex and all its faces. More...
simplifiable_status | is_remove_star_homotopy_preserving (const Simplex &simplex) |
| virtual contractible_status | is_contractible () const |
| | Test if the complex is reducible using a strategy defined in the class (by default it tests if the complex is a cone) More...
Root_simplex_handle | get_id (const Simplex &local_simplex) const |
| | returns a simplex with vertices which are the id of vertices of the argument.
Blocker_handle | add_blocker (const Simplex &blocker) |
| | Adds the simplex to the set of blockers and returns a Blocker_handle toward it if was not present before and 0 otherwise.
| void | remove_blocker (const Blocker_handle sigma) |
| | Removes the simplex from the set of blockers. More...
void | remove_blockers () |
| | Remove all blockers, in other words, it expand the simplicial complex to the smallest flag complex that contains it.
| void | delete_blocker (Blocker_handle sigma) |
| bool | contains_blocker (const Blocker_handle s) const |
| bool | contains_blocker (const Simplex &s) const |
| Link_complex | link (Vertex_handle v) const |
| Link_complex | link (Edge_handle edge) const |
| Link_complex | link (const Simplex &simplex) const |
| boost::optional< Simplex > | get_simplex_address (const Root_simplex_handle &s) const |
| | Compute the local vertices of 's' in the current complex If one of them is not present in the complex then the return value is uninitialized. More...
virtual bool | contains (const Simplex &s) const |
| | returns true iff the simplex s belongs to the simplicial complex.
bool | empty () const |
int | num_vertices () const |
int | num_edges () const |
int | num_triangles () const |
size_t | num_simplices () const |
size_t | num_simplices (int dimension) const |
size_t | num_blockers () const |
bool | complete () const |
int | num_connected_components () const |
| | returns the number of connected components in the graph of the 1-skeleton.
| bool | is_cone () const |
| | Test if the complex is a cone. More...
Complex_vertex_range | vertex_range () const |
| | Returns a Complex_vertex_range over all vertices of the complex.
Complex_neighbors_vertices_range | vertex_range (Vertex_handle v) const |
| | Returns a Complex_edge_range over all edges of the simplicial complex that passes through v.
Complex_edge_range | edge_range () const |
| | Returns a Complex_edge_range over all edges of the simplicial complex.
Complex_edge_around_vertex_range | edge_range (Vertex_handle v) const |
| | Returns a Complex_edge_range over all edges of the simplicial complex that passes through 'v'.
| Complex_triangle_around_vertex_range | triangle_range (Vertex_handle v) const |
| | Range over triangles around a vertex of the simplicial complex. Methods .begin() and .end() return a Triangle_around_vertex_iterator. More...
| Complex_triangle_range | triangle_range () const |
| | Range over triangles of the simplicial complex. Methods .begin() and .end() return a Triangle_around_vertex_iterator. More...
Complex_simplex_around_vertex_range | star_simplex_range (Vertex_handle v) const |
| | Returns a Complex_simplex_around_vertex_range over all the simplices around a vertex of the complex.
Complex_coboundary_range | coboundary_range (const Simplex &s) const |
| | Returns a Complex_simplex_coboundary_iterator over the simplices of the coboundary of a simplex.
Complex_simplex_range | complex_simplex_range () const |
| | Returns a Complex_simplex_range over all the simplices of the complex.
| Skeleton_blocker_complex (size_t num_vertices_=0, Visitor *visitor_=NULL) |
| | constructs a simplicial complex with a given number of vertices and a visitor.
| | Skeleton_blocker_complex (SimpleHandleOutputIterator simplices_begin, SimpleHandleOutputIterator simplices_end, bool is_flag_complex=false, Visitor *visitor_=NULL) |
| Skeleton_blocker_complex (const Skeleton_blocker_complex ©) |
Skeleton_blocker_complex & | operator= (const Skeleton_blocker_complex ©) |
| bool | operator== (const Skeleton_blocker_complex &other) const |
bool | operator!= (const Skeleton_blocker_complex &other) const |
| virtual | ~Skeleton_blocker_complex () |
| virtual void | clear () |
void | set_visitor (Visitor *other_visitor) |
| | allows to change the visitor.
Complex_blocker_around_vertex_range | blocker_range (Vertex_handle v) |
| | Returns a range of the blockers of the complex passing through a vertex.
Complex_blocker_range | blocker_range () |
| | Returns a range of the blockers of the complex.
Const_complex_blocker_around_vertex_range | const_blocker_range (Vertex_handle v) const |
Const_complex_blocker_range | const_blocker_range () const |
| bool | link_condition (Vertex_handle a, Vertex_handle b, bool ignore_popable_blockers=false) const |
| bool | link_condition (Edge_handle e, bool ignore_popable_blockers=false) const |
| void | contract_edge (Edge_handle edge) |
| void | contract_edge (Vertex_handle a, Vertex_handle b) |
