#include <gudhi/Bottleneck.h>
#include <iostream>
#include <vector>
#include <utility>
#include <string>
#include <limits>
int main(int argc, char** argv) {
  if (argc < 3) {
    std::clog << "To run this program please provide as an input two files with persistence diagrams. Each file" <<
        " should contain a birth-death pair per line. Third, optional parameter is an error bound on the bottleneck" <<
        " distance (set by default to the smallest positive double value). If you set the error bound to 0, be" <<
        " aware this version is exact but expensive. The program will now terminate \n";
    return -1;
  std::vector<std::pair<double, double>> diag1 =
Gudhi::read_persistence_intervals_in_dimension(argv[1]);
  std::vector<std::pair<double, double>> diag2 = Gudhi::read_persistence_intervals_in_dimension(argv[2]);
  double tolerance = std::numeric_limits<double>::min();
  if (argc == 4) {
    tolerance = atof(argv[3]);
  std::clog << "The distance between the diagrams is : " << b << ". The tolerance is : " << tolerance << std::endl;
  return 0;
double bottleneck_distance(const Persistence_diagram1 &diag1, const Persistence_diagram2 &diag2, double e=(std::numeric_limits< double >::min)())
Function to compute the Bottleneck distance between two persistence diagrams.
Definition: Bottleneck.h:116
This file includes common file reader for GUDHI.
