Searching...
No Matches
SimplexTreeOptions Struct Reference
Concept of the template parameter for the class Gudhi::Simplex_tree<SimplexTreeOptions>. More...
#include <concept/Simplex_tree/SimplexTreeOptions.h>
Public Types
typedef IndexingTag Indexing_tag
 Forced for now.
typedef VertexHandle Vertex_handle
 Must be a signed integer type. It admits a total order <.
typedef FiltrationValue Filtration_value
 Must be comparable with operator<.
typedef SimplexKey Simplex_key
 Must be an integer type.
Static Public Attributes
static const bool store_key
 If true, each simplex has extra storage for one Simplex_key. Necessary for Persistent_cohomology.
static const bool store_filtration
 If true, each simplex has extra storage for one Filtration_value, and this value is propagated by operations like Gudhi::Simplex_tree::expansion. Without it, Persistent_cohomology degenerates to computing usual (non-persistent) cohomology.
static constexpr bool contiguous_vertices
 If true, the list of vertices present in the complex must always be 0, ..., num_vertices-1, without any hole.
Detailed Description
One model for this is Gudhi::Simplex_tree_options_full_featured. If you want to provide your own, it is recommended that you derive from it and override some parts instead of writing a class from scratch.
The documentation for this struct was generated from the following file:
