All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Searching...
No Matches
Gudhi::coxeter_triangulation::Linear_transformation< Function_ > Class Template Reference
Transforms the zero-set of the function by a given linear transformation. The underlying function corresponds to f(M*x), where M is the transformation matrix. More...
#include <include/gudhi/Functions/Linear_transformation.h>
Public Member Functions
Eigen::VectorXd operator() (const Eigen::VectorXd &p) const
 Value of the function at a specified point. More...
std::size_t amb_d () const
 Returns the domain (ambient) dimension.
std::size_t cod_d () const
 Returns the codomain dimension.
Eigen::VectorXd seed () const
 Returns a point on the zero-set.
 Linear_transformation (const Function_ &function, const Eigen::MatrixXd &matrix)
 Constructor of a linearly transformed function. More...
Detailed Description
template<class Function_>
class Gudhi::coxeter_triangulation::Linear_transformation< Function_ >
Template Parameters
Function_The function template parameter. Should be a model of the concept FunctionForImplicitManifold.
Constructor & Destructor Documentation
◆ Linear_transformation()
template<class Function_ >
Gudhi::coxeter_triangulation::Linear_transformation< Function_ >::Linear_transformation ( const Function_ &  function,
const Eigen::MatrixXd &  matrix
inline
Parameters
[in]functionThe function to be linearly transformed.
[in]matrixThe transformation matrix. Its dimension should be d*d, where d is the domain (ambient) dimension of 'function'.
Member Function Documentation
◆ operator()()
Eigen::VectorXd Gudhi::coxeter_triangulation::Linear_transformation< Function_ >::operator() ( const Eigen::VectorXd &  p) const
inline
Parameters
[in]pThe input point. The dimension needs to coincide with the ambient dimension.
The documentation for this class was generated from the following file:
