All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Searching...
No Matches
Gudhi::persistent_cohomology::Multi_field Class Reference
Structure representing coefficients in a set of finite fields simultaneously using the chinese remainder theorem. More...
#include <include/gudhi/Persistent_cohomology/Multi_field.h>
Public Member Functions
const Element & additive_identity () const
 Returns the additive idendity 0k of the field.
const Element & multiplicative_identity () const
 Returns the multiplicative identity 1k of the field.
Element times (const Element &y, const Element &w)
const Element & characteristic () const
 Returns the characteristic p of the field.
std::pair< Element, Element > inverse (Element x, Element QS)
Element times_minus (const Element &x, const Element &y)
Element plus_times_equal (const Element &x, const Element &y, const Element &w)
- Public Member Functions inherited from CoefficientField
 CoefficientField ()
Element characteristic ()
Element multiplicative_identity ()
Element additive_identity ()
void plus_equal (Element x, Element y)
Additional Inherited Members
- Public Types inherited from CoefficientField
typedef unspecified Element
 Type of element of the field. More...
Detailed Description
Details on the algorithms may be found in [6]
Examples
rips_multifield_persistence.cpp.
Member Function Documentation
◆ inverse()
std::pair< Element, Element > Gudhi::persistent_cohomology::Multi_field::inverse ( Element  x,
Element  QS
inline
Returns the inverse in the field. Modifies P. ???
◆ plus_times_equal()
Element Gudhi::persistent_cohomology::Multi_field::plus_times_equal ( const Element &  x,
const Element &  y,
const Element &  w
inline
Set x <- x + w * y
◆ times()
Element Gudhi::persistent_cohomology::Multi_field::times ( const Element &  y,
const Element &  w
inline
Returns y * w
◆ times_minus()
Element Gudhi::persistent_cohomology::Multi_field::times_minus ( const Element &  x,
const Element &  y
inline
Returns -x * y.
The documentation for this class was generated from the following file:
