All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Searching...
No Matches
Gudhi::cubical_complex::Bitmap_cubical_complex< T > Class Template Reference
Cubical complex represented as a bitmap. More...
#include <include/gudhi/Bitmap_cubical_complex.h>
Classes
class  Filtration_simplex_range
 Filtration_simplex_range provides the ranges for Filtration_simplex_iterator. More...
class  Skeleton_simplex_range
 Class needed for compatibility with Gudhi. Not useful for other purposes. More...
Public Types
typedef std::vector< Simplex_handle >::iterator Boundary_simplex_iterator
Public Member Functions
 Bitmap_cubical_complex (const char *perseus_style_file)
 Bitmap_cubical_complex (const std::vector< unsigned > &dimensions, const std::vector< Filtration_value > &top_dimensional_cells)
 Bitmap_cubical_complex (const std::vector< unsigned > &dimensions, const std::vector< Filtration_value > &top_dimensional_cells, std::vector< bool > directions_in_which_periodic_b_cond_are_to_be_imposed)
virtual ~Bitmap_cubical_complex ()
std::size_t num_simplices () const
std::size_t dimension () const
unsigned dimension (Simplex_handle sh) const
Filtration_value filtration (Simplex_handle sh)
Simplex_key key (Simplex_handle sh) const
Simplex_handle simplex (Simplex_key key)
void assign_key (Simplex_handle sh, Simplex_key key)
void initialize_simplex_associated_to_key ()
Boundary_simplex_range boundary_simplex_range (Simplex_handle sh)
Filtration_simplex_range filtration_simplex_range ()
std::pair< Simplex_handle, Simplex_handle > endpoints (Simplex_handle sh)
Skeleton_simplex_range skeleton_simplex_range (unsigned dimension)
Static Public Member Functions
static Simplex_handle null_simplex ()
static Simplex_key null_key ()
Detailed Description
template<typename T>
class Gudhi::cubical_complex::Bitmap_cubical_complex< T >
This is a Bitmap_cubical_complex class. It joints a functionalities of Bitmap_cubical_complex_base and Bitmap_cubical_complex_periodic_boundary_conditions_base classes into Gudhi persistent homology engine. It is a template class that inherit from its template parameter. The template parameter is supposed to be either Bitmap_cubical_complex_base or Bitmap_cubical_complex_periodic_boundary_conditions_base class.
Examples
Random_bitmap_cubical_complex.cpp, cubical_complex_persistence.cpp, and periodic_cubical_complex_persistence.cpp.
Member Typedef Documentation
◆ Boundary_simplex_iterator
template<typename T >
typedef std::vector<Simplex_handle>::iterator Gudhi::cubical_complex::Bitmap_cubical_complex< T >::Boundary_simplex_iterator
Boundary_simplex_range class provides ranges for boundary iterators.
Constructor & Destructor Documentation
◆ Bitmap_cubical_complex() [1/3]
Gudhi::cubical_complex::Bitmap_cubical_complex< T >::Bitmap_cubical_complex ( const char *  perseus_style_file)
inline
Constructor form a Perseus-style file.
◆ Bitmap_cubical_complex() [2/3]
Gudhi::cubical_complex::Bitmap_cubical_complex< T >::Bitmap_cubical_complex ( const std::vector< unsigned > &  dimensions,
const std::vector< Filtration_value > &  top_dimensional_cells
inline
Constructor that requires vector of elements of type unsigned, which gives number of top dimensional cells in the following directions and vector of element of a type T with filtration on top dimensional cells.
◆ Bitmap_cubical_complex() [3/3]
const std::vector< Filtration_value > &  top_dimensional_cells,
inline
Constructor that requires vector of elements of type unsigned, which gives number of top dimensional cells in the following directions and vector of element of a type Filtration_value with filtration on top dimensional cells. The last parameter of the constructor is a vector of boolean of a length equal to the dimension of cubical complex. If the position i on this vector is true, then we impose periodic boundary conditions in this direction.
◆ ~Bitmap_cubical_complex()
virtual Gudhi::cubical_complex::Bitmap_cubical_complex< T >::~Bitmap_cubical_complex ( )
inlinevirtual
Destructor of the Bitmap_cubical_complex class.
Member Function Documentation
◆ assign_key()
void Gudhi::cubical_complex::Bitmap_cubical_complex< T >::assign_key ( Simplex_handle  sh,
Simplex_key  key
inline
Assign key to a cube pointed by the Simplex_handle
◆ boundary_simplex_range()
Boundary_simplex_range Gudhi::cubical_complex::Bitmap_cubical_complex< T >::boundary_simplex_range ( Simplex_handle  sh)
inline
boundary_simplex_range creates an object of a Boundary_simplex_range class that provides ranges for the Boundary_simplex_iterator.
◆ dimension() [1/2]
std::size_t Gudhi::cubical_complex::Bitmap_cubical_complex< T >::dimension ( ) const
inline
Returns dimension of the complex.
◆ dimension() [2/2]
unsigned Gudhi::cubical_complex::Bitmap_cubical_complex< T >::dimension ( Simplex_handle  sh) const
inline
Return dimension of a cell pointed by the Simplex_handle.
◆ endpoints()
std::pair< Simplex_handle, Simplex_handle > Gudhi::cubical_complex::Bitmap_cubical_complex< T >::endpoints ( Simplex_handle  sh)
inline
Function needed for compatibility with Gudhi. Not useful for other purposes.
◆ filtration()
Filtration_value Gudhi::cubical_complex::Bitmap_cubical_complex< T >::filtration ( Simplex_handle  sh)
inline
Return the filtration of a cell pointed by the Simplex_handle.
◆ filtration_simplex_range()
Filtration_simplex_range Gudhi::cubical_complex::Bitmap_cubical_complex< T >::filtration_simplex_range ( )
inline
filtration_simplex_range creates an object of a Filtration_simplex_range class that provides ranges for the Filtration_simplex_iterator.
◆ initialize_simplex_associated_to_key()
void Gudhi::cubical_complex::Bitmap_cubical_complex< T >::initialize_simplex_associated_to_key
Function called from a constructor. It is needed for Filtration_simplex_iterator to work.
◆ key()
Simplex_key Gudhi::cubical_complex::Bitmap_cubical_complex< T >::key ( Simplex_handle  sh) const
inline
Return the key of a cube pointed by the Simplex_handle.
◆ null_key()
static Simplex_key Gudhi::cubical_complex::Bitmap_cubical_complex< T >::null_key ( )
inlinestatic
Return a key which is not a key of any cube in the considered data structure.
◆ null_simplex()
static Simplex_handle Gudhi::cubical_complex::Bitmap_cubical_complex< T >::null_simplex ( )
inlinestatic
Returns a Simplex_handle to a cube that do not exist in this complex.
◆ num_simplices()
std::size_t Gudhi::cubical_complex::Bitmap_cubical_complex< T >::num_simplices ( ) const
inline
Returns number of all cubes in the complex.
◆ simplex()
Simplex_handle Gudhi::cubical_complex::Bitmap_cubical_complex< T >::simplex ( Simplex_key  key)
inline
Return the Simplex_handle given the key of the cube.
◆ skeleton_simplex_range()
Skeleton_simplex_range Gudhi::cubical_complex::Bitmap_cubical_complex< T >::skeleton_simplex_range ( unsigned  dimension)
inline
The documentation for this class was generated from the following file:
