All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Searching...
No Matches
Gudhi::Simplex_tree_siblings< SimplexTree, MapContainer > Class Template Reference
Data structure to store a set of nodes in a SimplexTree sharing the same parent node. More...
#include <include/gudhi/Simplex_tree/Simplex_tree_siblings.h>
Public Member Functions
template<typename RandomAccessVertexRange >
 Simplex_tree_siblings (Simplex_tree_siblings *oncles, Vertex_handle parent, const RandomAccessVertexRange &members)
 Constructor with initialized set of members. More...
void insert (Vertex_handle v, Filtration_value filtration_value)
 Inserts a Node in the set of siblings nodes. More...
Detailed Description
template<class SimplexTree, class MapContainer>
class Gudhi::Simplex_tree_siblings< SimplexTree, MapContainer >
Constructor & Destructor Documentation
◆ Simplex_tree_siblings()
template<class SimplexTree , class MapContainer >
Gudhi::Simplex_tree_siblings< SimplexTree, MapContainer >::Simplex_tree_siblings ( Simplex_tree_siblings< SimplexTree, MapContainer > *  oncles,
const RandomAccessVertexRange &  members
inline
'members' must be sorted and unique.
Member Function Documentation
◆ insert()
void Gudhi::Simplex_tree_siblings< SimplexTree, MapContainer >::insert ( Vertex_handle  v,
inline
If already present, assigns the minimal filtration value between input filtration_value and the value already present in the node.
The documentation for this class was generated from the following file:
