12#ifndef SIMPLEX_TREE_SIMPLEX_TREE_ITERATORS_H_
13#define SIMPLEX_TREE_SIMPLEX_TREE_ITERATORS_H_
15#include <gudhi/Debug_utils.h>
17#include <boost/iterator/iterator_facade.hpp>
18#include <boost/container/static_vector.hpp>
34template<
class SimplexTree>
36 Simplex_tree_simplex_vertex_iterator<SimplexTree>,
37 typename SimplexTree::Vertex_handle const, boost::forward_traversal_tag,
38 typename SimplexTree::Vertex_handle const> {
56 friend class boost::iterator_core_access;
59 return sib_ == other.sib_ && v_ == other.v_;
68 sib_ = sib_->oncles();
80template<
class SimplexTree>
82 Simplex_tree_boundary_simplex_iterator<SimplexTree>,
83 typename SimplexTree::Simplex_handle const, boost::forward_traversal_tag> {
104 template<
class SimplexHandle>
112 if (SimplexTree::Options::contiguous_vertices)
113 GUDHI_CHECK(st_->contiguous_vertices(),
"The set of vertices is not { 0, ..., n } without holes");
115 next_ = sib->parent();
116 sib_ = sib->oncles();
117 if (sib_ !=
nullptr) {
118 if (SimplexTree::Options::contiguous_vertices && sib_->oncles() ==
nullptr)
120 sh_ = sib_->members_.begin()+next_;
122 sh_ = sib_->find(next_);
127 friend class boost::iterator_core_access;
130 return sh_ == other.sh_;
133 Simplex_handle
const& dereference()
const {
139 if (sib_ ==
nullptr) {
145 Siblings * new_sib = sib_->oncles();
146 auto rit = suffix_.rbegin();
147 if (SimplexTree::Options::contiguous_vertices && new_sib ==
nullptr) {
149 if (rit == suffix_.rend()) {
151 sh_ = for_sib->members_.begin()+last_;
156 sh_ = for_sib->members_.begin()+*rit;
157 for_sib = sh_->second.children();
161 for (; rit != suffix_.rend(); ++rit) {
162 sh_ = for_sib->find(*rit);
163 for_sib = sh_->second.children();
165 sh_ = for_sib->find(last_);
166 suffix_.push_back(next_);
167 next_ = sib_->parent();
176 boost::container::static_vector<Vertex_handle, 40> suffix_;
187template<
class SimplexTree>
189 Simplex_tree_boundary_opposite_vertex_simplex_iterator<SimplexTree>,
190 std::pair<typename SimplexTree::Simplex_handle, typename SimplexTree::Vertex_handle> const, boost::forward_traversal_tag> {
212 template<
220 if (SimplexTree::Options::contiguous_vertices)
221 GUDHI_CHECK(st_->contiguous_vertices(),
223 next_ = sib->parent();
224 sib_ = sib->oncles();
225 if (sib_ !=
nullptr) {
226 if (SimplexTree::Options::contiguous_vertices && sib_->oncles() ==
nullptr)
228 baov_.first = sib_->members_.begin()+next_;
230 baov_.first = sib_->find(next_);
235 friend class boost::iterator_core_access;
239 return (baov_.first == other.baov_.first);
242 std::pair<Simplex_handle, Vertex_handle>
const {
247 if (sib_ ==
nullptr) {
251 Siblings * for_sib = sib_;
252 Siblings * new_sib = sib_->oncles();
253 auto rit = suffix_.rbegin();
254 if (SimplexTree::Options::contiguous_vertices && new_sib ==
nullptr) {
256 if (rit == suffix_.rend()) {
257 baov_.second = baov_.first->first;
259 baov_.first = for_sib->members_.begin()+last_;
264 baov_.first = for_sib->members_.begin()+*rit;
265 for_sib = baov_.first->second.children();
269 for (; rit != suffix_.rend(); ++rit) {
270 baov_.first = for_sib->find(*rit);
271 for_sib = baov_.first->second.children();
273 baov_.first = for_sib->find(last_);
274 suffix_.push_back(next_);
275 next_ = sib_->parent();
277 baov_.second = suffix_.back();
285 boost::container::static_vector<Vertex_handle, 40> suffix_;
289 std::pair<Simplex_handle, Vertex_handle> baov_;
297template<
class SimplexTree>
299 Simplex_tree_complex_simplex_iterator<SimplexTree>,
300 typename SimplexTree::Simplex_handle const, boost::forward_traversal_tag> {
315 if (st ==
nullptr || st->
root() ==
nullptr || st->
root()->members().empty()) {
318 sh_ = st->
root()->members().begin();
321 sib_ = sh_->second.children();
322 sh_ = sib_->members().begin();
327 friend class boost::iterator_core_access;
331 if (other.st_ ==
nullptr) {
332 return (st_ ==
nullptr);
334 if (st_ ==
nullptr) {
337 return (&(sh_->second) == &(other.sh_->second));
340 Simplex_handle
const {
347 if (sh_ == sib_->members().end()) {
348 if (sib_->oncles() ==
nullptr) {
352 sh_ = sib_->oncles()->members().find(sib_->parent());
353 sib_ = sib_->oncles();
357 sib_ = sh_->second.children();
358 sh_ = sib_->members().begin();
371template<
class SimplexTree>
373 Simplex_tree_skeleton_simplex_iterator<SimplexTree>,
374 typename SimplexTree::Simplex_handle const, boost::forward_traversal_tag> {
393 if (st ==
nullptr || st->
root() ==
nullptr || st->
396 sh_ = st->
398 while (st->
has_children(sh_) && curr_dim_ < dim_skel_) {
399 sib_ = sh_->second.children();
400 sh_ = sib_->members().begin();
406 friend class boost::iterator_core_access;
410 if (other.st_ ==
nullptr) {
411 return (st_ ==
nullptr);
413 if (st_ ==
nullptr) {
416 return (&(sh_->second) == &(other.sh_->second));
419 Simplex_handle
const {
426 if (sh_ == sib_->members().end()) {
427 if (sib_->oncles() ==
nullptr) {
431 sh_ = sib_->oncles()->members().find(sib_->parent());
432 sib_ = sib_->oncles();
436 while (st_->
437 sib_ = sh_->second.children();
438 sh_ = sib_->members().begin();
Iterator over the simplices of the boundary of a simplex and their opposite vertices.
Definition: Simplex_tree_iterators.h:190
Iterator over the simplices of the boundary of a simplex.
Definition: Simplex_tree_iterators.h:83
Iterator over the simplices of a simplicial complex.
Definition: Simplex_tree_iterators.h:300
Iterator over the vertices of a simplex in a SimplexTree.
Definition: Simplex_tree_iterators.h:38
Iterator over the simplices of the skeleton of a given dimension of the simplicial complex.
Definition: Simplex_tree_iterators.h:374
Simplex Tree data structure for representing simplicial complexes.
Definition: Simplex_tree.h:81
static Siblings * self_siblings(SimplexHandle sh)
Definition: Simplex_tree.h:886
Dictionary::iterator Simplex_handle
Handle type to a simplex contained in the simplicial complex represented by the simplex tree.
Definition: Simplex_tree.h:154
Vertex_handle null_vertex() const
Returns a Vertex_handle different from all Vertex_handles associated to the vertices of the simplicia...
Definition: Simplex_tree.h:569
bool has_children(SimplexHandle sh) const
Returns true if the node in the simplex tree pointed by sh has children.
Definition: Simplex_tree.h:630
Simplex_tree_siblings< Simplex_tree, Dictionary > Siblings
Set of nodes sharing a same parent in the simplex tree.
Definition: Simplex_tree.h:107
Options::Vertex_handle Vertex_handle
Type for the vertex handle.
Definition: Simplex_tree.h:96
Siblings * root()
Definition: Simplex_tree.h:895
static Simplex_handle null_simplex()
Returns a Simplex_handle different from all Simplex_handles associated to the simplices in the simpli...
Definition: Simplex_tree.h:558
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
