All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
CoefficientField Struct Reference
Concept describing the requirements for a class to represent a field of coefficients to compute persistent homology. More...
#include <concept/Persistent_cohomology/CoefficientField.h>
Public Types
typedef unspecified Element
 Type of element of the field. More...
Public Member Functions
 CoefficientField ()
Element characteristic ()
Element multiplicative_identity ()
Element additive_identity ()
void plus_equal (Element x, Element y)
Detailed Description
Member Typedef Documentation
◆ Element
typedef unspecified CoefficientField::Element
Must be Assignable.
Constructor & Destructor Documentation
◆ CoefficientField()
CoefficientField::CoefficientField ( )
Default constructible.
Member Function Documentation
◆ additive_identity()
Element CoefficientField::additive_identity ( )
Return the element 0 of the field.
◆ characteristic()
Element CoefficientField::characteristic ( )
Return the characteristic of the field.
◆ multiplicative_identity()
Element CoefficientField::multiplicative_identity ( )
Return the element 1 of the field.
◆ plus_equal()
void CoefficientField::plus_equal ( Element  x,
Element  y
Assign: x <- x + y
The documentation for this struct was generated from the following file:
