All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Persistent Cohomology
Classes
class  Gudhi::persistent_cohomology::Persistent_cohomology< FilteredComplex, CoefficientField >
 Computes the persistent cohomology of a filtered complex. More...
class  Gudhi::persistent_cohomology::Field_Zp
 Structure representing the coefficient field Z/pZ. More...
class  Gudhi::persistent_cohomology::Multi_field
 Structure representing coefficients in a set of finite fields simultaneously using the chinese remainder theorem. More...
Detailed Description
Author
Clément Maria
Computation of persistent cohomology using the algorithm of [22] and [25] and the Compressed Annotation Matrix implementation of [8]
The theory of homology consists in attaching to a topological space a sequence of (homology) groups, capturing global topological features like connected components, holes, cavities, etc. Persistent homology studies the evolution – birth, life and death – of these features when the topological space is changing. Consequently, the theory is essentially composed of three elements: topological spaces, their homology groups and an evolution scheme.
Topological Spaces
Topological spaces are represented by simplicial complexes. Let V={1,,|V|} be a set of vertices. A simplex σ is a subset of vertices σV. A simplicial complex K on V is a collection of simplices {σ}, σV, such that τσKτK. The dimension n=|σ|1 of σ is its number of elements minus 1. A filtration of a simplicial complex is a function f:KR satisfying f(τ)f(σ) whenever τσ.
We define the concept FilteredComplex which enumerates the requirements for a class to represent a filtered complex from which persistent homology may be computed. We use the vocabulary of simplicial complexes, but the concept is valid for any type of cell complex. The main requirements are the definition of:
Homology
For a ring R, the group of n-chains, denoted Cn(K,R), of K is the group of formal sums of n-simplices with R coefficients. The boundary operator is a linear operator n:Cn(K,R)Cn1(K,R) such that nσ=n[v0,,vn]=i=0n(1)i[v0,,vi^,,vn], where vi^ means vi is omitted from the list. The chain groups form a sequence:
  Cn(K,R) n Cn1(K,R)n1 2 C1(K,R) 1 C0(K,R)
of finitely many groups Cn(K,R) and homomorphisms n, indexed by the dimension n0. The boundary operators satisfy the property nn+1=0 for every n>0 and we define the homology groups:
Hn(K,R)=kern/im n+1
We refer to [38] for an introduction to homology theory and to [27] for an introduction to persistent homology.
Indexing Scheme
"Changing" a simplicial complex consists in applying a simplicial map. An indexing scheme is a directed graph together with a traversal order, such that two consecutive nodes in the graph are connected by an arrow (either forward or backward). The nodes represent simplicial complexes and the directed edges simplicial maps.
From the computational point of view, there are two types of indexing schemes of interest in persistent homology: linear ones in persistent homology [44] , and zigzag ones in zigzag persistent homology [13]. These indexing schemes have a natural left-to-right traversal order, and we describe them with ranges and iterators. In the current release of the Gudhi library, only the linear case is implemented.
In the following, we consider the case where the indexing scheme is induced by a filtration. Ordering the simplices by increasing filtration values (breaking ties so as a simplex appears after its subsimplices of same filtration value) provides an indexing scheme.
Examples
We provide several example files: run these examples with -h for details on their use, and read the README file.
More details on the Rips complex utilities dedicated page.
The file should contain square or lower triangular distance matrix with semicolons as separators. The code do not check if it is dealing with a distance matrix. It is the user responsibility to provide a valid input. Please refer to data/distance_matrix/lower_triangular_distance_matrix.csv for an example of a file.
Note that no check is performed if the matrix given as the input is a correlation matrix. It is the user responsibility to ensure that this is the case. The input is to be given either as a square or a lower triangular matrix. Please refer to data/correlation_matrix/lower_triangular_correlation_matrix.csv for an example of a file.
More details on the Alpha complex utilities dedicated page.
CGAL can be forced to compute the exact values, it is slower, but it is necessary when points are on a grid for instance (the fast version --fast would give incorrect values).
$> ./alpha_complex_3d_persistence ../../data/points/sphere3D_pts_on_grid.off --exact -p 2 -m 0.1
Simplex_tree dim: 3
2 0 0 inf
2 2 0.0002 0.2028
It can also compute the persistent homology with Z/2Z coefficients of the weighted alpha complex on points sampling from an OFF file and a weights file.
$> ./alpha_complex_3d_persistence ../../data/points/tore3D_300.off
--weight-file ../../data/points/tore3D_300.weights -p 2 -m 0.45
Simplex_tree dim: 3
2 0 -1 inf
2 1 -0.931784 0.000103311
2 1 -0.906588 2.60165e-05
2 2 -0.43556 0.0393798
One can also compute the persistent homology with Z/2Z coefficients of the periodic alpha complex on points sampling from an OFF file. The second parameter is a Iso-cuboid file with coordinates of the periodic cuboid. Note that the lengths of the sides of the periodic cuboid have to be the same.
$> ./alpha_complex_3d_persistence ../../data/points/grid_10_10_10_in_0_1.off
--cuboid-file ../../data/points/iso_cuboid_3_in_0_1.txt -p 3 -m 1.0
Simplex_tree dim: 3
3 0 0 inf
3 1 0.0025 inf
3 1 0.0025 inf
3 1 0.0025 inf
3 2 0.005 inf
3 2 0.005 inf
3 2 0.005 inf
3 3 0.0075 inf
In order to compute the persistent homology with Z/2Z coefficients of the periodic alpha complex on weighted points from an OFF file. The additional parameters of this program are:
(a) The file with the weights of points. The file consist of a sequence of numbers (as many as points). Note that the weight of each single point have to be bounded by 1/64 times the square of the cuboid edge length.
(b) A Iso-cuboid file with coordinates of the periodic cuboid. Note that the lengths of the sides of the periodic cuboid have to be the same.
$> ./alpha_complex_3d_persistence ../../data/points/shifted_sphere.off
--weight-file ../../data/points/shifted_sphere.weights
--cuboid-file ../../data/points/iso_cuboid_3_in_0_10.txt -p 3 -m 1.0
Simplex_tree dim: 3
3 0 -0.0001 inf
3 1 16.0264 inf
3 1 16.0273 inf
3 1 16.0303 inf
3 2 36.8635 inf
3 2 36.8704 inf
3 2 36.8838 inf
3 3 58.6783 inf
