Rips complex data structure.
More...
#include <include/gudhi/Rips_complex.h>
typedef boost::adjacency_list< boost::vecS, boost::vecS, boost::directedS, boost::property< vertex_filtration_t, Filtration_value >, boost::property< edge_filtration_t, Filtration_value > > | OneSkeletonGraph |
| | Type of the one skeleton graph stored inside the Rips complex structure.
template<typename
Filtration_value>
class Gudhi::rips_complex::Rips_complex< Filtration_value >
The data structure is a one skeleton graph, or Rips graph, containing edges when the edge length is less or equal to a given threshold. Edge length is computed from a user given point cloud with a given distance function, or a distance matrix.
- Template Parameters
| Filtration_value | is the type used to store the filtration values of the simplicial complex. |
- Examples
- alpha_rips_persistence_bottleneck_distance.cpp, example_one_skeleton_rips_from_correlation_matrix.cpp, example_one_skeleton_rips_from_distance_matrix.cpp, example_one_skeleton_rips_from_points.cpp, example_rips_complex_from_csv_distance_matrix_file.cpp, example_rips_complex_from_off_file.cpp, rips_correlation_matrix_persistence.cpp, rips_distance_matrix_persistence.cpp, rips_multifield_persistence.cpp, rips_persistence.cpp, and rips_persistence_via_boundary_matrix.cpp.
◆ Rips_complex() [1/2]
template<typename ForwardPointRange , typename Distance >
Rips_complex constructor from a list of points.
- Parameters
| [in] | points | Range of points. |
| [in] | threshold | Rips value. |
| [in] | distance | distance function that returns a Filtration_value from 2 given points. |
| ForwardPointRange | must be a range for which std::begin and std::end return input iterators on a point. |
| Distance | furnishes operator()(const Point& p1, const Point& p2), where Point is a point from the ForwardPointRange, and that returns a Filtration_value. |
◆ Rips_complex() [2/2]
template<typename DistanceMatrix >
Rips_complex constructor from a distance matrix.
- Parameters
| [in] | distance_matrix | Range of distances. |
| DistanceMatrix | must have a size() method and on which distance_matrix[i][j] returns the distance between points \(i\) and \(j\) as long as \( 0 \leqslant j < i \leqslant distance\_matrix.size().\) |
◆ create_complex()
The documentation for this class was generated from the following file:
