All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::Persistence_representations::Real_valued_topological_data Class Reference
The concept Real_valued_topological_data describes the requirements for a type to implement a container that allows computations of its projections to R. More...
#include <concept/Persistence_representations/Real_valued_topological_data.h>
Public Member Functions
size_t number_of_projections_to_R ()
double project_to_R (size_t number_of_projection)
Detailed Description
Member Function Documentation
◆ number_of_projections_to_R()
size_t Gudhi::Persistence_representations::Real_valued_topological_data::number_of_projections_to_R ( )
Typically there are various ways data can be projected to R. This function gives us the number of functions for vectorization provided by a given class.
◆ project_to_R()
double Gudhi::Persistence_representations::Real_valued_topological_data::project_to_R ( size_t  number_of_projection)
This is a function to compute the projection from this container to reals. The parameter of a function have to be between 0 and the value returned by number_of_projections_to_R().
The documentation for this class was generated from the following file:
