Hasse_complex.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Clément Maria
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef HASSE_COMPLEX_H_
12#define HASSE_COMPLEX_H_
13
14#include <gudhi/allocator.h>
15
16#include <boost/iterator/counting_iterator.hpp>
17
18#include <algorithm>
19#include <utility> // for pair
20#include <vector>
21#include <limits> // for infinity value
22
23#ifdef GUDHI_USE_TBB
24#include <tbb/parallel_for.h>
25#endif
26
27namespace Gudhi {
28
29template < class HasseCpx >
30struct Hasse_simplex {
31 // Complex_ds must verify that cpx->key(sh) is the order of sh in the filtration
32
33 template< class Complex_ds >
34 Hasse_simplex(Complex_ds & cpx
35 , typename Complex_ds::Simplex_handle sh)
36 : filtration_(cpx.filtration(sh))
37 , boundary_() {
38 boundary_.reserve(cpx.dimension(sh) + 1);
39 for (auto b_sh : cpx.boundary_simplex_range(sh)) {
40 boundary_.push_back(cpx.key(b_sh));
41 }
42 }
43
44 Hasse_simplex(typename HasseCpx::Simplex_key key
45 , typename HasseCpx::Filtration_value fil
46 , std::vector<typename HasseCpx::Simplex_handle> const& boundary)
47 : key_(key)
48 , filtration_(fil)
49 , boundary_(boundary) { }
50
51 typename HasseCpx::Simplex_key key_;
52 typename HasseCpx::Filtration_value filtration_;
53 std::vector<typename HasseCpx::Simplex_handle> boundary_;
54};
55
64template < typename FiltrationValue = double
65, typename SimplexKey = int
66, typename VertexHandle = int
67>
68class Hasse_complex {
69 public:
70 typedef Hasse_simplex<Hasse_complex> Hasse_simp;
72 typedef SimplexKey Simplex_key;
73 typedef int Simplex_handle; // index in vector complex_
74
75 typedef boost::counting_iterator< Simplex_handle > Filtration_simplex_iterator;
76 typedef boost::iterator_range<Filtration_simplex_iterator> Filtration_simplex_range;
77
78 typedef typename std::vector< Simplex_handle >::iterator Boundary_simplex_iterator;
79 typedef boost::iterator_range<Boundary_simplex_iterator> Boundary_simplex_range;
80
81 typedef typename std::vector< Simplex_handle >::iterator Skeleton_simplex_iterator;
82 typedef boost::iterator_range< Skeleton_simplex_iterator > Skeleton_simplex_range;
83
84 /* only dimension 0 skeleton_simplex_range(...) */
85 Skeleton_simplex_range skeleton_simplex_range(int dim = 0) {
86 if (dim != 0) {
87 std::cerr << "Dimension must be 0 \n";
88 }
89 return Skeleton_simplex_range(vertices_.begin(), vertices_.end());
90 }
91
92 template < class Complex_ds >
93 Hasse_complex(Complex_ds & cpx)
94 : complex_(cpx.num_simplices())
95 , vertices_()
96 , num_vertices_()
97 , dim_max_(cpx.dimension()) {
98 int size = complex_.size();
99#ifdef GUDHI_USE_TBB
100 tbb::parallel_for(0, size, [&](int idx){new (&complex_[idx]) Hasse_simp(cpx, cpx.simplex(idx));});
101 for (int idx=0; idx < size; ++idx)
102 if (complex_[idx].boundary_.empty())
103 vertices_.push_back(idx);
104#else
105 for (int idx=0; idx < size; ++idx) {
106 new (&complex_[idx]) Hasse_simp(cpx, cpx.simplex(idx));
107 if (complex_[idx].boundary_.empty())
108 vertices_.push_back(idx);
109 }
110#endif
111 }
112
113 Hasse_complex()
114 : complex_()
115 , vertices_()
116 , num_vertices_(0)
117 , dim_max_(-1) { }
118
119 size_t num_simplices() {
120 return complex_.size();
121 }
122
123 Filtration_simplex_range filtration_simplex_range() {
124 return Filtration_simplex_range(Filtration_simplex_iterator(0)
125 , Filtration_simplex_iterator(complex_.size()));
126 }
127
128 Simplex_key key(Simplex_handle sh) {
129 return complex_[sh].key_;
130 }
131
132 Simplex_key null_key() {
133 return -1;
134 }
135
136 Simplex_handle simplex(Simplex_key key) {
137 if (key == null_key()) return null_simplex();
138 return key;
139 }
140
141 Simplex_handle null_simplex() {
142 return -1;
143 }
144
145 Filtration_value filtration(Simplex_handle sh) {
146 if (sh == null_simplex()) {
147 return std::numeric_limits<Filtration_value>::infinity();
148 }
149 return complex_[sh].filtration_;
150 }
151
152 int dimension(Simplex_handle sh) {
153 if (complex_[sh].boundary_.empty()) return 0;
154 return complex_[sh].boundary_.size() - 1;
155 }
156
157 int dimension() {
158 return dim_max_;
159 }
160
161 std::pair<Simplex_handle, Simplex_handle> endpoints(Simplex_handle sh) {
162 return std::pair<Simplex_handle, Simplex_handle>(complex_[sh].boundary_[0]
163 , complex_[sh].boundary_[1]);
164 }
165
166 void assign_key(Simplex_handle sh, Simplex_key key) {
167 complex_[sh].key_ = key;
168 }
169
170 Boundary_simplex_range boundary_simplex_range(Simplex_handle sh) {
171 return Boundary_simplex_range(complex_[sh].boundary_.begin()
172 , complex_[sh].boundary_.end());
173 }
174
175 void display_simplex(Simplex_handle sh) {
176 std::clog << dimension(sh) << " ";
177 for (auto sh_b : boundary_simplex_range(sh)) std::clog << sh_b << " ";
178 std::clog << " " << filtration(sh) << " key=" << key(sh);
179 }
180
181 void initialize_filtration() {
182 // Setting the keys is done by pcoh, Simplex_tree doesn't do it either.
183#if 0
184 Simplex_key key = 0;
185 for (auto & h_simp : complex_)
186 h_simp.key_ = key++;
187#endif
188 }
189
190 std::vector< Hasse_simp, Gudhi::no_init_allocator<Hasse_simp> > complex_;
191 std::vector<Simplex_handle> vertices_;
192 size_t num_vertices_;
193 int dim_max_;
194};
195
196template< typename T1, typename T2, typename T3 >
197std::istream& operator>>(std::istream & is
198 , Hasse_complex< T1, T2, T3 > & hcpx) {
199 assert(hcpx.num_simplices() == 0);
200
201 size_t num_simp;
202 is >> num_simp;
203 hcpx.complex_.reserve(num_simp);
204
205 std::vector< typename Hasse_complex<T1, T2, T3>::Simplex_key > boundary;
206 typename Hasse_complex<T1, T2, T3>::Filtration_value fil;
207 typename Hasse_complex<T1, T2, T3>::Filtration_value max_fil = 0;
208 int max_dim = -1;
209 int key = 0;
210 // read all simplices in the file as a list of vertices
211 while (read_hasse_simplex(is, boundary, fil)) {
212 // insert every simplex in the simplex tree
213 hcpx.complex_.emplace_back(key, fil, boundary);
214
215 if (max_dim < hcpx.dimension(key)) {
216 max_dim = hcpx.dimension(key);
217 }
218 if (hcpx.dimension(key) == 0) {
219 hcpx.vertices_.push_back(key);
220 }
221 if (max_fil < fil) {
222 max_fil = fil;
223 }
224
225 ++key;
226 boundary.clear();
227 }
228
229 hcpx.dim_max_ = max_dim;
230
231 return is;
232}
233
234} // namespace Gudhi
235
236#endif // HASSE_COMPLEX_H_
bool read_hasse_simplex(std::istream &in_, std::vector< Simplex_key > &boundary, Filtration_value &fil)
Read a hasse simplex from a file.
Definition: reader_utils.h:183
Returns the filtration value of a simplex.
void assign_key(Simplex_handle sh, Simplex_key n)
Store a number for a simplex, which can later be retrieved with key(sh).
Returns the number stored for a simplex by assign_key.
Returns the dimension of a simplex.
Simplex_handle simplex(size_t idx)
Returns the simplex that has index idx in the filtration.
Returns a range giving access to all simplices of the boundary of a simplex, i.e. the set of codimens...
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
Key type used as simplex identifier.
Definition: SimplexKey.h:15
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
