Euclidean_witness_complex.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2015 Inria
6 *
7 * Modification(s):
8 * - 2019/08 Vincent Rouvreau: Fix issue #10 for CGAL and Eigen3
9 * - YYYY/MM Author: Description of the modification
10 */
11
12#ifndef EUCLIDEAN_WITNESS_COMPLEX_H_
13#define EUCLIDEAN_WITNESS_COMPLEX_H_
14
15#include <gudhi/Witness_complex.h>
16#include <gudhi/Active_witness/Active_witness.h>
17#include <gudhi/Kd_tree_search.h>
18
19#include <CGAL/version.h> // for CGAL_VERSION_NR
20
21#include <Eigen/src/Core/util/Macros.h> // for EIGEN_VERSION_AT_LEAST
22
23#include <utility>
24#include <vector>
25#include <list>
26#include <limits>
27
28// Make compilation fail - required for external projects - https://github.com/GUDHI/gudhi-devel/issues/10
29#if CGAL_VERSION_NR < 1041101000
30# error Euclidean_witness_complex is only available for CGAL >= 4.11
31#endif
32
33#if !EIGEN_VERSION_AT_LEAST(3,1,0)
34# error Euclidean_witness_complex is only available for Eigen3 >= 3.1.0 installed with CGAL
35#endif
36
37namespace Gudhi {
38
39namespace witness_complex {
40
50template< class Kernel_ >
52 : public Witness_complex<std::vector<typename Gudhi::spatial_searching::Kd_tree_search<Kernel_,
53 std::vector<typename Kernel_::Point_d>>::INS_range>> {
54 private:
55 typedef Kernel_ K;
56 typedef typename K::Point_d Point_d;
57 typedef std::vector<Point_d> Point_range;
59 typedef typename Kd_tree::INS_range Nearest_landmark_range;
60 typedef typename std::vector<Nearest_landmark_range> Nearest_landmark_table;
61
62 typedef typename Nearest_landmark_range::Point_with_transformed_distance Id_distance_pair;
63 typedef typename Id_distance_pair::first_type Landmark_id;
64 typedef Landmark_id Vertex_handle;
65
66 private:
67 Point_range landmarks_;
68 Kd_tree landmark_tree_;
70
71 public:
73 /* @name Constructor
74 */
75
77
84 template< typename LandmarkRange,
85 typename WitnessRange >
86 Euclidean_witness_complex(const LandmarkRange & landmarks,
87 const WitnessRange & witnesses)
88 : landmarks_(std::begin(landmarks), std::end(landmarks)), landmark_tree_(landmarks) {
89 nearest_landmark_table_.reserve(boost::size(witnesses));
90 for (auto w : witnesses)
91 nearest_landmark_table_.push_back(landmark_tree_.incremental_nearest_neighbors(w));
92 }
93
97 Point_d get_point(Vertex_handle vertex) const {
98 return landmarks_[vertex];
99 }
100
102};
103
104} // namespace witness_complex
105
106} // namespace Gudhi
107
108#endif // EUCLIDEAN_WITNESS_COMPLEX_H_
INS_range incremental_nearest_neighbors(Point const &p, FT eps=FT(0)) const
Search incrementally for the nearest neighbors from a query point.
Definition: Kd_tree_search.h:271
Incremental_neighbor_search INS_range
The range returned by an incremental nearest or furthest neighbor search. Its value type is std::pair...
Definition: Kd_tree_search.h:112
Constructs (weak) witness complex for given sets of witnesses and landmarks in Euclidean space.
Definition: Euclidean_witness_complex.h:53
Returns the point corresponding to the given vertex.
Definition: Euclidean_witness_complex.h:97
Euclidean_witness_complex(const LandmarkRange &landmarks, const WitnessRange &witnesses)
Initializes member variables before constructing simplicial complex.
Definition: Euclidean_witness_complex.h:86
Constructs (weak) witness complex for a given table of nearest landmarks with respect to witnesses.
Definition: Witness_complex.h:38
