The concept SimplicialComplexForRips describes the requirements for a type to implement a simplicial complex, that can be created from a Rips_complex. The only available model for the moment is the Simplex_tree.
More...
Public Member Functions | |
| template<class OneSkeletonGraph > | |
| void | insert_graph (const OneSkeletonGraph &skel_graph) |
Inserts a given Gudhi::rips_complex::Rips_complex::OneSkeletonGraph in the simplicial complex. | |
| void | expansion (int max_dim) |
| Expands the simplicial complex containing only its one skeleton until a given maximal dimension as explained in Rips complex definition. | |
| template<typename Blocker > | |
| void | expansion_with_blockers (int max_dim, Blocker block_simplex) |
Expands a simplicial complex containing only a graph. Simplices corresponding to cliques in the graph are added incrementally, faces before cofaces, unless the simplex has dimension larger than max_dim or block_simplex returns true for this simplex. More... | |
| unspecified | simplex_vertex_range (Simplex_handle sh) |
| Returns a range over the vertices of a simplex. | |
| std::size_t | num_vertices () |
| Returns the number of vertices in the simplicial complex. | |
| void Gudhi::rips_complex::SimplicialComplexForRips::expansion_with_blockers | ( | int | max_dim, |
| Blocker | block_simplex | ||
| [in] | max_dim | Expansion maximal dimension value. |
| [in] | block_simplex | Blocker oracle. Its concept is bool block_simplex(Simplex_handle sh) |
The function identifies a candidate simplex whose faces are all already in the complex, inserts it with a filtration value corresponding to the maximum of the filtration values of the faces, then calls block_simplex on a Simplex_handle for this new simplex. If block_simplex returns true, the simplex is removed, otherwise it is kept.
| GUDHI Version 3.5.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Thu Jan 13 2022 08:34:28 for GUDHI by Doxygen 1.9.2 |
