Constructs the "minus" function. The zero-set is the same, but the values at other points are the negative of their original value.
More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/Functions/Negation.h>
| Eigen::VectorXd | operator() (const Eigen::VectorXd &p) const |
| | Value of the function at a specified point. More...
std::size_t | amb_d () const |
| | Returns the domain (ambient) dimension.
std::size_t | cod_d () const |
| | Returns the codomain dimension.
Eigen::VectorXd | seed () const |
| | Returns a point on the zero-set.
| | Negation (const Function_ &function) |
| | Constructor of the negative function. More...
template<class Function_>
class Gudhi::coxeter_triangulation::Negation< Function_ >
- Template Parameters
◆ Negation()
template<class Function_ >
- Parameters
| [in] | function | The function to be negated. |
◆ operator()()
- Parameters
| [in] | p | The input point. The dimension needs to coincide with the ambient dimension. |
The documentation for this class was generated from the following file:
- /home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/Functions/Negation.h
