Structure to store a mesh that can be output in Medit .mesh file format using the output_meshes_to_medit method. More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/IO/Mesh_medit.h>
Public Types | |
| typedef std::vector< Eigen::VectorXd > | Vertex_points |
| Type of a range of vertices. | |
| typedef std::pair< std::vector< std::size_t >, std::size_t > | Mesh_element |
| Type of a mesh element. A pair consisting of a vector of vertex indices of type std::size_t and of an integer that represents the common reference number for the mesh elements of this type. | |
| typedef std::vector< Mesh_element > | Mesh_elements |
| Type of a range of mesh elements. | |
| typedef std::vector< double > | Scalar_field_range |
| Type of a range of scalar field . | |
Public Attributes | |
| Vertex_points | vertex_points |
| Range of vertices of type Eigen::VectorXd to output. | |
| Mesh_elements | edges |
| Range of edges. | |
| Mesh_elements | triangles |
| Range of triangles. | |
| Mesh_elements | tetrahedra |
| Range of tetrahedra. | |
| Scalar_field_range | triangles_scalar_range |
| Range of scalar values over triangles. | |
| Scalar_field_range | tetrahedra_scalar_range |
| Range of scalar values over tetrahedra. | |
| GUDHI Version 3.5.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Thu Jan 13 2022 08:34:28 for GUDHI by Doxygen 1.9.2 |
