Transforms the zero-set of the function by a given linear transformation. The underlying function corresponds to f(M*x), where M is the transformation matrix.
More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/Functions/Linear_transformation.h>
| Eigen::VectorXd | operator() (const Eigen::VectorXd &p) const |
| | Value of the function at a specified point. More...
std::size_t | amb_d () const |
| | Returns the domain (ambient) dimension.
std::size_t | cod_d () const |
| | Returns the codomain dimension.
Eigen::VectorXd | seed () const |
| | Returns a point on the zero-set.
| | Linear_transformation (const Function_ &function, const Eigen::MatrixXd &matrix) |
| | Constructor of a linearly transformed function. More...
template<class Function_>
class Gudhi::coxeter_triangulation::Linear_transformation< Function_ >
- Template Parameters
◆ Linear_transformation()
template<class Function_ >
- Parameters
| [in] | function | The function to be linearly transformed. |
| [in] | matrix | The transformation matrix. Its dimension should be d*d, where d is the domain (ambient) dimension of 'function'. |
◆ operator()()
- Parameters
| [in] | p | The input point. The dimension needs to coincide with the ambient dimension. |
The documentation for this class was generated from the following file:
