A class that encodes the function, the zero-set of which is a torus surface embedded in R^3.
More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/Functions/Function_torus_in_R3.h>
| Eigen::VectorXd | operator() (const Eigen::VectorXd &p) const |
| | Value of the function at a specified point. More...
std::size_t | amb_d () const |
| | Returns the domain (ambient) dimension.
std::size_t | cod_d () const |
| | Returns the codomain dimension.
Eigen::VectorXd | seed () const |
| | Returns a point on the surface.
| | Function_torus_in_R3 (double R=1, double r=0.5, Eigen::Vector3d off=Eigen::Vector3d::Zero()) |
| | Constructor of the function that defines a torus embedded in R^3. More...
◆ Function_torus_in_R3()
| Gudhi::coxeter_triangulation::Function_torus_in_R3::Function_torus_in_R3 |
double |
R = 1, |
double |
r = 0.5, |
Eigen::Vector3d |
off = Eigen::Vector3d::Zero() |
inline |
- Parameters
| [in] | R | The outer radius of the torus. |
| [in] | r | The inner radius of the torus. |
| [in] | off | Offset vector. |
◆ operator()()
| Eigen::VectorXd Gudhi::coxeter_triangulation::Function_torus_in_R3::operator() |
const Eigen::VectorXd & |
p | ) |
const |
inline |
- Parameters
| [in] | p | The input point. The dimension needs to coincide with the ambient dimension. |
The documentation for this class was generated from the following file:
