The concept SimplicialComplexForAlpha describes the requirements for a type to implement a simplicial complex, that can be created from a Alpha_complex.
More...
Public Types | |
| typedef unspecified | Simplex_handle |
| typedef unspecified | Vertex_handle |
| typedef unspecified | Filtration_value |
| typedef unspecified | Simplex_vertex_range |
| Iterator over vertices of a simplex. More... | |
| typedef unspecified | Boundary_simplex_range |
| Iterator over the boundaries of the complex, in an arbitrary order. More... | |
| typedef unspecified | Skeleton_simplex_range |
| Iterator over the simplices of the skeleton of the complex, for a given dimension. More... | |
| typedef unspecified | Insertion_result_type |
| Return type of an insertion of a simplex. | |
Public Member Functions | |
| std::size_t | num_vertices () |
| int | dimension (Simplex_handle simplex) |
| int | assign_filtration (Simplex_handle simplex, Filtration_value filtration) |
| void | insert_simplex_and_subfaces (std::vector< Vertex_handle > const &vertex_range, Filtration_value filtration) |
| Inserts a simplex with vertices from a given simplex (represented by a vector of Vertex_handle) in the simplicial complex with the given 'filtration' value. | |
| void | make_filtration_non_decreasing () |
| void | prune_above_filtration (Filtration_value filtration) |
| Simplex_vertex_range | simplex_vertex_range (Simplex_handle const &simplex) |
| Returns a range over vertices of a given simplex. | |
| Boundary_simplex_range | boundary_simplex_range (Simplex_handle const &simplex) |
| Returns a range over boundaries of a given simplex. | |
Public Attributes | |
| Skeleton_simplex_range | skeleton_simplex_range |
| Returns a range over the simplices of the skeleton of the simplicial complex, for a given dimension. | |
Map interface | |
Conceptually a | |
| typedef unspecified | Simplex_key |
| Data stored for each simplex. More... | |
| Simplex_key | null_key () |
| Returns a constant dummy number that is either negative, or at least as large as the number of simplices. Suggested value: -1. | |
| Simplex_key | key (Simplex_handle sh) |
Returns the number stored for a simplex by assign_key(). More... | |
| void | assign_key (Simplex_handle sh, Simplex_key n) |
Store a number for a simplex, which can later be retrieved with key(). | |
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha::Boundary_simplex_range |
'value_type' must be 'Simplex_handle'.
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha::Filtration_value |
Handle to specify the simplex filtration value.
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha::Simplex_handle |
Handle to specify a simplex.
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha::Simplex_key |
Must be an integer type.
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha::Simplex_vertex_range |
'value type' must be 'Vertex_handle'.
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha::Skeleton_simplex_range |
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha::Vertex_handle |
Handle to specify a vertex. Must be a non-negative integer.
| int Gudhi::alpha_complex::SimplicialComplexForAlpha::assign_filtration | ( | Simplex_handle | simplex, |
| Filtration_value | filtration | ||
Assigns the 'simplex' with the given 'filtration' value.
| int Gudhi::alpha_complex::SimplicialComplexForAlpha::dimension | ( | Simplex_handle | simplex | ) |
Gets the 'simplex' dimension.
| Simplex_key Gudhi::alpha_complex::SimplicialComplexForAlpha::key | ( | Simplex_handle | sh | ) |
If assign_key() has not been called, it must return null_key().
| void Gudhi::alpha_complex::SimplicialComplexForAlpha::make_filtration_non_decreasing | ( | ) |
Browses the simplicial complex to make the filtration non-decreasing.
| std::size_t Gudhi::alpha_complex::SimplicialComplexForAlpha::num_vertices | ( | ) |
Returns the number of vertices in the simplicial complex.
| void Gudhi::alpha_complex::SimplicialComplexForAlpha::prune_above_filtration | ( | Filtration_value | filtration | ) |
Prune the simplicial complex above 'filtration' value given as parameter.
| GUDHI Version 3.5.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2 |
