Class that allows to load a Skeleton_blocker_complex from an off file.
More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/Skeleton_blocker/Skeleton_blocker_off_io.h>
template<typename
Complex>
class Gudhi::skeleton_blocker::Skeleton_blocker_off_reader< Complex >
- Examples
- Garland_heckbert.cpp, and Rips_contraction.cpp.
◆ Skeleton_blocker_off_reader()
name_file : file to read read_complex : complex that will receive the file content read_only_points : specify true if only the points must be read
◆ is_valid()
return true if reading did not meet problems.
The documentation for this class was generated from the following file:
