Gudhi::coxeter_triangulation::Freudenthal_triangulation< Permutahedral_representation_ > Class Template Reference
A class that stores any affine transformation of the Freudenthal-Kuhn triangulation. More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/Freudenthal_triangulation.h>
Public Types
using Simplex_handle = Permutahedral_representation_
 Type of the simplices in the triangulation.
using Vertex_handle = typename Permutahedral_representation_::Vertex
 Type of the vertices in the triangulation.
Public Member Functions
 Freudenthal_triangulation (std::size_t dimension)
 Constructor of the Freudenthal-Kuhn triangulation of a given dimension. More...
 Freudenthal_triangulation (std::size_t dimension, const Matrix &matrix)
 Constructor of the Freudenthal-Kuhn triangulation of a given dimension under a linear transformation by a given matrix. More...
 Freudenthal_triangulation (unsigned dimension, const Matrix &matrix, const Vector &offset)
 Constructor of the Freudenthal-Kuhn triangulation of a given dimension under an affine transformation by a given matrix and a translation vector. More...
unsigned dimension () const
 Dimension of the triangulation.
const Matrix & matrix () const
 Matrix that defines the linear transformation of the triangulation.
const Vector & offset () const
 Vector that defines the offset of the triangulation.
void change_matrix (const Eigen::MatrixXd &matrix)
 Change the linear transformation matrix to a given value. More...
void change_offset (const Eigen::VectorXd &offset)
 Change the offset vector to a given value. More...
template<class Point_d >
Simplex_handle locate_point (const Point_d &point, double scale=1) const
 Returns the permutahedral representation of the simplex in the triangulation that contains a given query point. More...
Eigen::VectorXd cartesian_coordinates (const Vertex_handle &vertex, double scale=1) const
 Returns the Cartesian coordinates of the given vertex. More...
Eigen::VectorXd barycenter (const Simplex_handle &simplex, double scale=1) const
 Returns the Cartesian coordinates of the barycenter of a given simplex. More...
Detailed Description
template<class Permutahedral_representation_ = Permutahedral_representation<std::vector<int>, std::vector<std::vector<std::size_t> > >>
class Gudhi::coxeter_triangulation::Freudenthal_triangulation< Permutahedral_representation_ >
The data structure is a record that consists of a matrix that represents the linear transformation of the Freudenthal-Kuhn triangulation and a vector that represents the offset.
Template Parameters
Permutahedral_representation_Type of a simplex given by a permutahedral representation. Needs to be a model of SimplexInCoxeterTriangulation.
Constructor & Destructor Documentation
◆ Freudenthal_triangulation() [1/3]
Gudhi::coxeter_triangulation::Freudenthal_triangulation< Permutahedral_representation_ >::Freudenthal_triangulation ( std::size_t  dimension)
inline
Parameters
[in]dimensionThe dimension of the triangulation.
◆ Freudenthal_triangulation() [2/3]
Gudhi::coxeter_triangulation::Freudenthal_triangulation< Permutahedral_representation_ >::Freudenthal_triangulation ( std::size_t  dimension,
inline
Parameters
[in]matrixThe matrix that defines the linear transformation. Needs to be invertible.
◆ Freudenthal_triangulation() [3/3]
Gudhi::coxeter_triangulation::Freudenthal_triangulation< Permutahedral_representation_ >::Freudenthal_triangulation ( unsigned  dimension,
const Matrix &  matrix,
inline
Parameters
[in]offsetThe offset vector.
Exceptions
std::invalid_argumentIn debug mode, if offset size is different from dimension.
Member Function Documentation
◆ barycenter()
Eigen::VectorXd Gudhi::coxeter_triangulation::Freudenthal_triangulation< Permutahedral_representation_ >::barycenter ( const Simplex_handle simplex,
double  scale = 1
) const
inline
Using the additional parameter scale, the search can be done in a triangulation that shares the origin, but is scaled by a given factor. This parameter can be useful to simulate the computation of Cartesian coordinates of the barycenter of a simplex in a subdivided triangulation.
Parameters
[in]simplexThe query simplex.
[in]scaleThe scale of the triangulation.
◆ cartesian_coordinates()
Eigen::VectorXd Gudhi::coxeter_triangulation::Freudenthal_triangulation< Permutahedral_representation_ >::cartesian_coordinates ( const Vertex_handle vertex,
double  scale = 1
) const
inline
Using the additional parameter scale, the search can be done in a triangulation that shares the origin, but is scaled by a given factor. This parameter can be useful to simulate the computation of Cartesian coordinates of a vertex in a subdivided triangulation.
Parameters
[in]vertexThe query vertex.
◆ change_matrix()
void Gudhi::coxeter_triangulation::Freudenthal_triangulation< Permutahedral_representation_ >::change_matrix ( const Eigen::MatrixXd &  matrix)
inline
Parameters
[in]matrixNew value of the linear transformation matrix.
◆ change_offset()
void Gudhi::coxeter_triangulation::Freudenthal_triangulation< Permutahedral_representation_ >::change_offset ( const Eigen::VectorXd &  offset)
inline
Parameters
[in]offsetNew value of the offset vector.
◆ locate_point()
Simplex_handle Gudhi::coxeter_triangulation::Freudenthal_triangulation< Permutahedral_representation_ >::locate_point ( const Point_d &  point,
double  scale = 1
) const
inline
Using the additional parameter scale, the search can be done in a triangulation that shares the origin, but is scaled by a given factor. This parameter can be useful to simulate the point location in a subdivided triangulation. The returned simplex is always minimal by inclusion.
Template Parameters
Point_dA class that represents a point in d-dimensional Euclidean space. The coordinates should be random-accessible. Needs to provide the method size().
Parameters
[in]pointThe query point.
Exceptions
std::invalid_argumentIn debug mode, if point dimension is different from triangulation one.
The documentation for this class was generated from the following file:
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:28 for GUDHI by Doxygen 1.9.2
