Interface for a visitor of the edge contraction process.
More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/Contraction/policies/Contraction_visitor.h>
virtual void | on_started (ComplexType &complex) |
| | Called before the edge contraction process starts.
virtual void | on_stop_condition_reached () |
| | Called when the algorithm stops.
virtual void | on_collected (const Profile &profile, boost::optional< FT > cost) |
| | Called during the collecting phase (when a cost is assigned to the edges), for each edge collected.
virtual void | on_selected (const Profile &profile, boost::optional< FT > cost, int initial_count, int current_count) |
| | Called during the processing phase (when edges are contracted), for each edge that is selected.
virtual void | on_contracting (const Profile &profile, boost::optional< Point > placement) |
| | Called when an edge is about to be contracted and replaced by a vertex whose position is *placement.
virtual void | on_contracted (const Profile &profile, boost::optional< Point > placement) |
| | Called when after an edge has been contracted onto a new point placement. A possibility would to remove popable blockers at this point for instance.
virtual void | on_non_valid (const Profile &profile) |
| | Called for each selected edge which cannot be contracted because the ValidContractionPredicate is false.
template<typename EdgeProfile>
class Gudhi::contraction::Contraction_visitor< EdgeProfile >
- Examples
- Garland_heckbert.cpp.
The documentation for this class was generated from the following file:
- /home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/Contraction/policies/Contraction_visitor.h
