OFF file reader top class visitor. More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/Off_reader.h>
Public Member Functions | |
| template<typename OffVisitor > | |
| bool | read (OffVisitor &off_visitor) |
| Read an OFF file and calls the following methods : More... | |
OFF file must be conform to OFF file format
inline |
void init(int dim,int num_vertices,int num_faces,int num_edges); // from file header - num_edges may not be set
void point(const std::vector<double>& point); // for each point read
void maximal_face(const std::list<int>& face); // for each face read
void done(); // upon file read is finished
of the visitor when reading a point or a maximal face. Edges are not taken into account.
| GUDHI Version 3.5.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2 |
