Points_3D_off_io.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Vincent Rouvreau
4 *
5 * Copyright (C) 2015 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10#ifndef POINTS_3D_OFF_IO_H_
11#define POINTS_3D_OFF_IO_H_
12
13#include <gudhi/Off_reader.h>
14
15#include <string>
16#include <vector>
17#include <fstream>
18#include <map>
19
20namespace Gudhi {
21
25template<typename Point_3>
27 private:
28 std::vector<Point_3> point_cloud_;
29 bool valid_;
30
31 public:
42 void init(int dim, int num_vertices, int num_faces, int num_edges) {
43#ifdef DEBUG_TRACES
44 std::clog << "Points_3D_off_visitor_reader::init - dim=" << dim << " - num_vertices=" <<
45 num_vertices << " - num_faces=" << num_faces << " - num_edges=" << num_edges << std::endl;
46#endif // DEBUG_TRACES
47 if (dim == 3) {
48 valid_ = true;
49 } else {
50 valid_ = false;
51 std::cerr << "Points_3D_off_reader::Points_3D_off_reader cannot read OFF files in dimension " << dim << "\n";
52 }
53
54 if (num_faces > 0) {
55 std::cerr << "Points_3D_off_visitor_reader::init faces are not taken into account from OFF file for Points.\n";
56 }
57 if (num_edges > 0) {
58 std::cerr << "Points_3D_off_visitor_reader::init edges are not taken into account from OFF file for Points.\n";
59 }
60 }
61
74 void point(const std::vector<double>& point) {
75 if (valid_) {
76#ifdef DEBUG_TRACES
77 std::clog << "Points_3D_off_visitor_reader::point ";
78 for (auto coordinate : point) {
79 std::clog << coordinate << " | ";
80 }
81 std::clog << std::endl;
82#endif // DEBUG_TRACES
83 // Fill the point cloud
84 point_cloud_.push_back(Point_3(point[0], point[1], point[2]));
85 }
86 }
87
88 // Off_reader visitor maximal_face implementation - Only points are read
89
90 void maximal_face(const std::vector<int>& face) { }
91
92 // Off_reader visitor done implementation - Only points are read
93
94 void done() { }
95
100 const std::vector<Point_3>& get_point_cloud() const {
101 return point_cloud_;
102 }
103
108 bool is_valid() const {
109 return valid_;
110 }
111};
112
139template<typename Point_3>
141 public:
149 Points_3D_off_reader(const std::string& name_file)
150 : valid_(false) {
151 std::ifstream stream(name_file);
152 if (stream.is_open()) {
153 Off_reader off_reader(stream);
155 valid_ = off_reader.read(off_visitor);
156 valid_ = valid_ && off_visitor.is_valid();
157 if (valid_) {
158 point_cloud = off_visitor.get_point_cloud();
159 }
160 } else {
161 std::cerr << "Points_3D_off_reader::Points_3D_off_reader could not open file " << name_file << "\n";
162 }
163 }
164
169 bool is_valid() const {
170 return valid_;
171 }
172
177 const std::vector<Point_3>& get_point_cloud() const {
178 return point_cloud;
179 }
180
181 private:
183 std::vector<Point_3> point_cloud;
185 bool valid_;
186};
187
188} // namespace Gudhi
189
190#endif // POINTS_3D_OFF_IO_H_
OFF file reader top class visitor.
Definition: Off_reader.h:29
bool read(OffVisitor &off_visitor)
Read an OFF file and calls the following methods :
Definition: Off_reader.h:51
Definition: Points_3D_off_io.h:140
Points_3D_off_reader(const std::string &name_file)
Reads the OFF file and constructs a vector of points from the points that are in the OFF file.
Definition: Points_3D_off_io.h:149
Returns if the OFF file read operation was successful or not.
Definition: Points_3D_off_io.h:169
const std::vector< Point_3 > & get_point_cloud() const
Point cloud getter.
Definition: Points_3D_off_io.h:177
OFF file visitor implementation according to Off_reader in order to read points from an OFF file.
Definition: Points_3D_off_io.h:26
Definition: Points_3D_off_io.h:108
Point cloud getter.
Definition: Points_3D_off_io.h:100
Off_reader visitor init implementation.
Definition: Points_3D_off_io.h:42
void point(const std::vector< double > &point)
Off_reader visitor point implementation.
Definition: Points_3D_off_io.h:74
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
