Coxeter_triangulation.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2019 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef COXETER_TRIANGULATION_H_
12#define COXETER_TRIANGULATION_H_
13
14#include <vector>
15#include <cmath> // for std::sqrt
16
17#include <boost/range/iterator_range.hpp>
18#include <boost/graph/graph_traits.hpp>
19#include <boost/graph/adjacency_list.hpp>
20
21#include <Eigen/Eigenvalues>
22#include <Eigen/Sparse>
23#include <Eigen/SVD>
24
25#include <gudhi/Freudenthal_triangulation.h>
26#include <gudhi/Permutahedral_representation.h>
27
28namespace Gudhi {
29
30namespace coxeter_triangulation {
31
43template <class Permutahedral_representation_ =
44 Permutahedral_representation<std::vector<int>, std::vector<std::vector<std::size_t> > > >
45class Coxeter_triangulation : public Freudenthal_triangulation<Permutahedral_representation_> {
46 using Matrix = Eigen::MatrixXd;
47
48 Matrix root_matrix(unsigned d) {
49 Matrix cartan(Matrix::Identity(d, d));
50 for (unsigned i = 1; i < d; i++) {
51 cartan(i - 1, i) = -0.5;
52 cartan(i, i - 1) = -0.5;
53 }
54 Eigen::SelfAdjointEigenSolver<Matrix> saes(cartan);
55 Eigen::VectorXd sqrt_diag(d);
56 for (unsigned i = 0; i < d; ++i) sqrt_diag(i) = std::sqrt(saes.eigenvalues()[i]);
57
58 Matrix lower(Matrix::Ones(d, d));
59 lower = lower.triangularView<Eigen::Lower>();
60
61 Matrix result = (lower * saes.eigenvectors() * sqrt_diag.asDiagonal()).inverse();
62 return result;
63 }
64
65 public:
70 : Freudenthal_triangulation<Permutahedral_representation_>(dimension, root_matrix(dimension)) {}
71};
72
73} // namespace coxeter_triangulation
74
75} // namespace Gudhi
76
77#endif
A class that stores Coxeter triangulation of type . This triangulation has the greatest simplex quali...
Definition: Coxeter_triangulation.h:45
Coxeter_triangulation(std::size_t dimension)
Constructor of Coxeter triangulation of a given dimension.
Definition: Coxeter_triangulation.h:69
A class that stores any affine transformation of the Freudenthal-Kuhn triangulation.
Definition: Freudenthal_triangulation.h:46
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
