Bitmap_cubical_complex_base.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Pawel Dlotko
4 *
5 * Copyright (C) 2015 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef BITMAP_CUBICAL_COMPLEX_BASE_H_
12#define BITMAP_CUBICAL_COMPLEX_BASE_H_
13
14#include <gudhi/Bitmap_cubical_complex/counter.h>
15
16#include <boost/config.hpp>
17
18#include <iostream>
19#include <vector>
20#include <string>
21#include <fstream>
22#include <algorithm>
23#include <iterator>
24#include <limits>
25#include <utility>
26#include <stdexcept>
27#include <cstddef>
28
29namespace Gudhi {
30
31namespace cubical_complex {
32
52template <typename T>
54 public:
55 typedef T filtration_type;
56
60 Bitmap_cubical_complex_base() : total_number_of_cells(0) {}
67 Bitmap_cubical_complex_base(const std::vector<unsigned>& sizes);
74 Bitmap_cubical_complex_base(const char* perseus_style_file);
79 Bitmap_cubical_complex_base(const std::vector<unsigned>& dimensions, const std::vector<T>& top_dimensional_cells);
80
85
97 virtual inline std::vector<std::size_t> get_boundary_of_a_cell(std::size_t cell) const;
112 virtual inline std::vector<std::size_t> get_coboundary_of_a_cell(std::size_t cell) const;
113
122 inline size_t get_top_dimensional_coface_of_a_cell(size_t splx);
123
143 virtual int compute_incidence_between_cells(std::size_t coface, std::size_t face) const {
144 // first get the counters for coface and face:
145 std::vector<unsigned> coface_counter = this->compute_counter_for_given_cell(coface);
146 std::vector<unsigned> face_counter = this->compute_counter_for_given_cell(face);
147
148 // coface_counter and face_counter should agree at all positions except from one:
149 int number_of_position_in_which_counters_do_not_agree = -1;
150 std::size_t number_of_full_faces_that_comes_before = 0;
151 for (std::size_t i = 0; i != coface_counter.size(); ++i) {
152 if ((coface_counter[i] % 2 == 1) && (number_of_position_in_which_counters_do_not_agree == -1)) {
153 ++number_of_full_faces_that_comes_before;
154 }
155 if (coface_counter[i] != face_counter[i]) {
156 if (number_of_position_in_which_counters_do_not_agree != -1) {
157 std::cerr << "Cells given to compute_incidence_between_cells procedure do not form a pair of coface-face.\n";
158 throw std::logic_error(
159 "Cells given to compute_incidence_between_cells procedure do not form a pair of coface-face.");
160 }
161 number_of_position_in_which_counters_do_not_agree = i;
162 }
163 }
164
165 int incidence = 1;
166 if (number_of_full_faces_that_comes_before % 2) incidence = -1;
167 // if the face cell is on the right from coface cell:
168 if (coface_counter[number_of_position_in_which_counters_do_not_agree] + 1 ==
169 face_counter[number_of_position_in_which_counters_do_not_agree]) {
170 incidence *= -1;
171 }
172
173 return incidence;
174 }
175
184 inline unsigned get_dimension_of_a_cell(std::size_t cell) const;
185
192 inline T& get_cell_data(std::size_t cell);
193
202 void impose_lower_star_filtration(); // assume that top dimensional cells are already set.
203
207 inline unsigned dimension() const { return sizes.size(); }
208
212 inline std::size_t size() const { return this->data.size(); }
213
218 template <typename K>
219 friend std::ostream& operator<<(std::ostream& os, const Bitmap_cubical_complex_base<K>& b);
220
229 void put_data_to_bins(std::size_t number_of_bins);
230
241 void put_data_to_bins(T diameter_of_bin);
242
246 std::pair<T, T> min_max_filtration();
247
248 // ITERATORS
249
254 class All_cells_iterator : std::iterator<std::input_iterator_tag, T> {
255 public:
256 All_cells_iterator() { this->counter = 0; }
257
258 All_cells_iterator operator++() {
259 // first find first element of the counter that can be increased:
260 ++this->counter;
261 return *this;
262 }
263
264 All_cells_iterator operator++(int) {
265 All_cells_iterator result = *this;
266 ++(*this);
267 return result;
268 }
269
270 All_cells_iterator& operator=(const All_cells_iterator& rhs) {
271 this->counter = rhs.counter;
272 return *this;
273 }
274
275 bool operator==(const All_cells_iterator& rhs) const {
276 if (this->counter != rhs.counter) return false;
277 return true;
278 }
279
280 bool operator!=(const All_cells_iterator& rhs) const { return !(*this == rhs); }
281
282 /*
283 * The operator * returns position of a cube in the structure of cubical complex. This position can be then used as
284 * an argument of the following functions:
285 * get_boundary_of_a_cell, get_coboundary_of_a_cell, get_dimension_of_a_cell to get information about the cell
286 * boundary and coboundary and dimension
287 * and in function get_cell_data to get a filtration of a cell.
288 */
289 std::size_t operator*() { return this->counter; }
290 friend class Bitmap_cubical_complex_base;
291
292 protected:
293 std::size_t counter;
294 };
295
301 return a;
302 }
303
309 a.counter = this->data.size();
310 return a;
311 }
312
317 public:
319
320 All_cells_iterator begin() { return b->all_cells_iterator_begin(); }
321
322 All_cells_iterator end() { return b->all_cells_iterator_end(); }
323
324 private:
326 };
327
328 All_cells_range all_cells_range() { return All_cells_range(this); }
329
333 typedef typename std::vector<std::size_t>::const_iterator Boundary_iterator;
334 typedef typename std::vector<std::size_t> Boundary_range;
335
340 Boundary_range boundary_range(std::size_t sh) { return this->get_boundary_of_a_cell(sh); }
341
345 typedef typename std::vector<std::size_t>::const_iterator Coboundary_iterator;
346 typedef typename std::vector<std::size_t> Coboundary_range;
347
352 Coboundary_range coboundary_range(std::size_t sh) { return this->get_coboundary_of_a_cell(sh); }
353
358 class Top_dimensional_cells_iterator : std::iterator<std::input_iterator_tag, T> {
359 public:
361 this->counter = std::vector<std::size_t>(b.dimension());
362 // std::fill( this->counter.begin() , this->counter.end() , 0 );
363 }
364
365 Top_dimensional_cells_iterator operator++() {
366 // first find first element of the counter that can be increased:
367 std::size_t dim = 0;
368 while ((dim != this->b.dimension()) && (this->counter[dim] == this->b.sizes[dim] - 1)) ++dim;
369
370 if (dim != this->b.dimension()) {
371 ++this->counter[dim];
372 for (std::size_t i = 0; i != dim; ++i) {
373 this->counter[i] = 0;
374 }
375 } else {
376 ++this->counter[0];
377 }
378 return *this;
379 }
380
381 Top_dimensional_cells_iterator operator++(int) {
382 Top_dimensional_cells_iterator result = *this;
383 ++(*this);
384 return result;
385 }
386
388 this->counter = rhs.counter;
389 this->b = rhs.b;
390 return *this;
391 }
392
393 bool operator==(const Top_dimensional_cells_iterator& rhs) const {
394 if (&this->b != &rhs.b) return false;
395 if (this->counter.size() != rhs.counter.size()) return false;
396 for (std::size_t i = 0; i != this->counter.size(); ++i) {
397 if (this->counter[i] != rhs.counter[i]) return false;
398 }
399 return true;
400 }
401
402 bool operator!=(const Top_dimensional_cells_iterator& rhs) const { return !(*this == rhs); }
403
404 /*
405 * The operator * returns position of a cube in the structure of cubical complex. This position can be then used as
406 * an argument of the following functions:
407 * get_boundary_of_a_cell, get_coboundary_of_a_cell, get_dimension_of_a_cell to get information about the cell
408 * boundary and coboundary and dimension
409 * and in function get_cell_data to get a filtration of a cell.
410 */
411 std::size_t operator*() { return this->compute_index_in_bitmap(); }
412
413 std::size_t compute_index_in_bitmap() const {
414 std::size_t index = 0;
415 for (std::size_t i = 0; i != this->counter.size(); ++i) {
416 index += (2 * this->counter[i] + 1) * this->b.multipliers[i];
417 }
418 return index;
419 }
420
421 void print_counter() const {
422 for (std::size_t i = 0; i != this->counter.size(); ++i) {
423 std::clog << this->counter[i] << " ";
424 }
425 }
426 friend class Bitmap_cubical_complex_base;
427
428 protected:
429 std::vector<std::size_t> counter;
431 };
432
438 return a;
439 }
440
446 for (std::size_t i = 0; i != this->dimension(); ++i) {
447 a.counter[i] = this->sizes[i] - 1;
448 }
449 a.counter[0]++;
450 return a;
451 }
452
457 public:
459
461
463
464 private:
466 };
467
468 Top_dimensional_cells_range top_dimensional_cells_range() { return Top_dimensional_cells_range(this); }
469
470 //****************************************************************************************************************//
471 //****************************************************************************************************************//
472 //****************************************************************************************************************//
473 //****************************************************************************************************************//
474
475 inline std::size_t number_cells() const { return this->total_number_of_cells; }
476
477 //****************************************************************************************************************//
478 //****************************************************************************************************************//
479 //****************************************************************************************************************//
480 //****************************************************************************************************************//
481
482 protected:
483 std::vector<unsigned> sizes;
484 std::vector<unsigned> multipliers;
485 std::vector<T> data;
486 std::size_t total_number_of_cells;
487
488 void set_up_containers(const std::vector<unsigned>& sizes) {
489 unsigned multiplier = 1;
490 for (std::size_t i = 0; i != sizes.size(); ++i) {
491 this->sizes.push_back(sizes[i]);
492 this->multipliers.push_back(multiplier);
493 multiplier *= 2 * sizes[i] + 1;
494 }
495 this->data = std::vector<T>(multiplier, std::numeric_limits<T>::infinity());
496 this->total_number_of_cells = multiplier;
497 }
498
499 std::size_t compute_position_in_bitmap(const std::vector<unsigned>& counter) {
500 std::size_t position = 0;
501 for (std::size_t i = 0; i != this->multipliers.size(); ++i) {
502 position += this->multipliers[i] * counter[i];
503 }
504 return position;
505 }
506
507 std::vector<unsigned> compute_counter_for_given_cell(std::size_t cell) const {
508 std::vector<unsigned> counter;
509 counter.reserve(this->sizes.size());
510 for (std::size_t dim = this->sizes.size(); dim != 0; --dim) {
511 counter.push_back(cell / this->multipliers[dim - 1]);
512 cell = cell % this->multipliers[dim - 1];
513 }
514 std::reverse(counter.begin(), counter.end());
515 return counter;
516 }
517 void read_perseus_style_file(const char* perseus_style_file);
518 void setup_bitmap_based_on_top_dimensional_cells_list(const std::vector<unsigned>& sizes_in_following_directions,
519 const std::vector<T>& top_dimensional_cells);
520 Bitmap_cubical_complex_base(const char* perseus_style_file, std::vector<bool> directions);
521 Bitmap_cubical_complex_base(const std::vector<unsigned>& sizes, std::vector<bool> directions);
522 Bitmap_cubical_complex_base(const std::vector<unsigned>& dimensions, const std::vector<T>& top_dimensional_cells,
523 std::vector<bool> directions);
524};
525
526template <typename T>
527void Bitmap_cubical_complex_base<T>::put_data_to_bins(std::size_t number_of_bins) {
528 bool dbg = false;
529
530 std::pair<T, T> min_max = this->min_max_filtration();
531 T dx = (min_max.second - min_max.first) / (T)number_of_bins;
532
533 // now put the data into the appropriate bins:
534 for (std::size_t i = 0; i != this->data.size(); ++i) {
535 if (dbg) {
536 std::clog << "Before binning : " << this->data[i] << std::endl;
537 }
538 this->data[i] = min_max.first + dx * (this->data[i] - min_max.first) / number_of_bins;
539 if (dbg) {
540 std::clog << "After binning : " << this->data[i] << std::endl;
541 }
542 }
543}
544
545template <typename T>
547 bool dbg = false;
548 std::pair<T, T> min_max = this->min_max_filtration();
549
550 std::size_t number_of_bins = (min_max.second - min_max.first) / diameter_of_bin;
551 // now put the data into the appropriate bins:
552 for (std::size_t i = 0; i != this->data.size(); ++i) {
553 if (dbg) {
554 std::clog << "Before binning : " << this->data[i] << std::endl;
555 }
556 this->data[i] = min_max.first + diameter_of_bin * (this->data[i] - min_max.first) / number_of_bins;
557 if (dbg) {
558 std::clog << "After binning : " << this->data[i] << std::endl;
559 }
560 }
561}
562
563template <typename T>
565 std::pair<T, T> min_max(std::numeric_limits<T>::infinity(), -std::numeric_limits<T>::infinity());
566 for (std::size_t i = 0; i != this->data.size(); ++i) {
567 if (this->data[i] < min_max.first) min_max.first = this->data[i];
568 if (this->data[i] > min_max.second) min_max.second = this->data[i];
569 }
570 return min_max;
571}
572
573template <typename K>
574std::ostream& operator<<(std::ostream& out, const Bitmap_cubical_complex_base<K>& b) {
575 for (typename Bitmap_cubical_complex_base<K>::all_cells_const_iterator it = b.all_cells_const_begin();
576 it != b.all_cells_const_end(); ++it) {
577 out << *it << " ";
578 }
579 return out;
580}
581
582template <typename T>
584 this->set_up_containers(sizes);
585}
586
587template <typename T>
589 const std::vector<unsigned>& sizes_in_following_directions, const std::vector<T>& top_dimensional_cells) {
590 this->set_up_containers(sizes_in_following_directions);
591
592 std::size_t number_of_top_dimensional_elements = 1;
593 for (std::size_t i = 0; i != sizes_in_following_directions.size(); ++i) {
594 number_of_top_dimensional_elements *= sizes_in_following_directions[i];
595 }
596 if (number_of_top_dimensional_elements != top_dimensional_cells.size()) {
597 std::cerr << "Error in constructor Bitmap_cubical_complex_base ( std::vector<std::size_t> "
598 << "sizes_in_following_directions, std::vector<T> top_dimensional_cells ). Number of top dimensional "
599 << "elements that follow from sizes_in_following_directions vector is different than the size of "
600 << "top_dimensional_cells vector."
601 << std::endl;
602 throw(
603 "Error in constructor Bitmap_cubical_complex_base( std::vector<std::size_t> sizes_in_following_directions,"
604 "std::vector<T> top_dimensional_cells ). Number of top dimensional elements that follow from "
605 "sizes_in_following_directions vector is different than the size of top_dimensional_cells vector.");
606 }
607
608 Bitmap_cubical_complex_base<T>::Top_dimensional_cells_iterator it(*this);
609 std::size_t index = 0;
610 for (it = this->top_dimensional_cells_iterator_begin(); it != this->top_dimensional_cells_iterator_end(); ++it) {
611 this->get_cell_data(*it) = top_dimensional_cells[index];
612 ++index;
613 }
614 this->impose_lower_star_filtration();
615}
616
617template <typename T>
619 if (this->get_dimension_of_a_cell(splx) == this->dimension()){return splx;}
620 else{
621 for (auto v : this->get_coboundary_of_a_cell(splx)){
622 if(this->get_cell_data(v) == this->get_cell_data(splx)){
623 return this->get_top_dimensional_coface_of_a_cell(v);
624 }
625 }
626 }
627 BOOST_UNREACHABLE_RETURN(-2);
628}
629
630template <typename T>
631Bitmap_cubical_complex_base<T>::Bitmap_cubical_complex_base(const std::vector<unsigned>& sizes_in_following_directions,
632 const std::vector<T>& top_dimensional_cells) {
633 this->setup_bitmap_based_on_top_dimensional_cells_list(sizes_in_following_directions, top_dimensional_cells);
634}
635
636template <typename T>
637void Bitmap_cubical_complex_base<T>::read_perseus_style_file(const char* perseus_style_file) {
638 bool dbg = false;
639 std::ifstream inFiltration;
640 inFiltration.open(perseus_style_file);
641 unsigned dimensionOfData;
642 inFiltration >> dimensionOfData;
643
644 if (dbg) {
645 std::clog << "dimensionOfData : " << dimensionOfData << std::endl;
646 }
647
648 std::vector<unsigned> sizes;
649 sizes.reserve(dimensionOfData);
650 // all dimensions multiplied
651 std::size_t dimensions = 1;
652 for (std::size_t i = 0; i != dimensionOfData; ++i) {
653 unsigned size_in_this_dimension;
654 inFiltration >> size_in_this_dimension;
655 sizes.push_back(size_in_this_dimension);
656 dimensions *= size_in_this_dimension;
657 if (dbg) {
658 std::clog << "size_in_this_dimension : " << size_in_this_dimension << std::endl;
659 }
660 }
661 this->set_up_containers(sizes);
662
663 Bitmap_cubical_complex_base<T>::Top_dimensional_cells_iterator it(*this);
664 it = this->top_dimensional_cells_iterator_begin();
665
666 T filtrationLevel = 0.;
667 std::size_t filtration_counter = 0;
668 while (!inFiltration.eof()) {
669 std::string line;
670 getline(inFiltration, line);
671 if (line.length() != 0) {
672 int n = sscanf(line.c_str(), "%lf", &filtrationLevel);
673 if (n != 1) {
674 std::string perseus_error("Bad Perseus file format. This line is incorrect : " + line);
675 throw std::ios_base::failure(perseus_error.c_str());
676 }
677
678 if (dbg) {
679 std::clog << "Cell of an index : " << it.compute_index_in_bitmap()
680 << " and dimension: " << this->get_dimension_of_a_cell(it.compute_index_in_bitmap())
681 << " get the value : " << filtrationLevel << std::endl;
682 }
683 this->get_cell_data(*it) = filtrationLevel;
684 ++it;
685 ++filtration_counter;
686 }
687 }
688
689 if (filtration_counter != dimensions) {
690 std::string perseus_error("Bad Perseus file format. Read " + std::to_string(filtration_counter) + " expected " + \
691 std::to_string(dimensions) + " values");
692 throw std::ios_base::failure(perseus_error.c_str());
693 }
694
695 inFiltration.close();
696 this->impose_lower_star_filtration();
697}
698
699template <typename T>
701 std::vector<bool> directions) {
702 // this constructor is here just for compatibility with a class that creates cubical complexes with periodic boundary
703 // conditions.
704 // It ignores the last parameter of the function.
705 this->read_perseus_style_file(perseus_style_file);
706}
707
708template <typename T>
709Bitmap_cubical_complex_base<T>::Bitmap_cubical_complex_base(const std::vector<unsigned>& sizes,
710 std::vector<bool> directions) {
711 // this constructor is here just for compatibility with a class that creates cubical complexes with periodic boundary
712 // conditions.
713 // It ignores the last parameter of the function.
714 this->set_up_containers(sizes);
715}
716
717template <typename T>
718Bitmap_cubical_complex_base<T>::Bitmap_cubical_complex_base(const std::vector<unsigned>& dimensions,
719 const std::vector<T>& top_dimensional_cells,
720 std::vector<bool> directions) {
721 // this constructor is here just for compatibility with a class that creates cubical complexes with periodic boundary
722 // conditions.
723 // It ignores the last parameter of the function.
724 this->setup_bitmap_based_on_top_dimensional_cells_list(dimensions, top_dimensional_cells);
725}
726
727template <typename T>
729 this->read_perseus_style_file(perseus_style_file);
730}
731
732template <typename T>
733std::vector<std::size_t> Bitmap_cubical_complex_base<T>::get_boundary_of_a_cell(std::size_t cell) const {
734 std::vector<std::size_t> boundary_elements;
735
736 // Speed traded of for memory. Check if it is better in practice.
737 boundary_elements.reserve(this->dimension() * 2);
738
739 std::size_t sum_of_dimensions = 0;
740 std::size_t cell1 = cell;
741 for (std::size_t i = this->multipliers.size(); i != 0; --i) {
742 unsigned position = cell1 / this->multipliers[i - 1];
743 if (position % 2 == 1) {
744 if (sum_of_dimensions % 2) {
745 boundary_elements.push_back(cell + this->multipliers[i - 1]);
746 boundary_elements.push_back(cell - this->multipliers[i - 1]);
747 } else {
748 boundary_elements.push_back(cell - this->multipliers[i - 1]);
749 boundary_elements.push_back(cell + this->multipliers[i - 1]);
750 }
751 ++sum_of_dimensions;
752 }
753 cell1 = cell1 % this->multipliers[i - 1];
754 }
755
756 return boundary_elements;
757}
758
759template <typename T>
760std::vector<std::size_t> Bitmap_cubical_complex_base<T>::get_coboundary_of_a_cell(std::size_t cell) const {
761 std::vector<unsigned> counter = this->compute_counter_for_given_cell(cell);
762 std::vector<std::size_t> coboundary_elements;
763 std::size_t cell1 = cell;
764 for (std::size_t i = this->multipliers.size(); i != 0; --i) {
765 unsigned position = cell1 / this->multipliers[i - 1];
766 if (position % 2 == 0) {
767 if ((cell > this->multipliers[i - 1]) && (counter[i - 1] != 0)) {
768 coboundary_elements.push_back(cell - this->multipliers[i - 1]);
769 }
770 if ((cell + this->multipliers[i - 1] < this->data.size()) && (counter[i - 1] != 2 * this->sizes[i - 1])) {
771 coboundary_elements.push_back(cell + this->multipliers[i - 1]);
772 }
773 }
774 cell1 = cell1 % this->multipliers[i - 1];
775 }
776 return coboundary_elements;
777}
778
779template <typename T>
781 bool dbg = false;
782 if (dbg) std::clog << "\n\n\n Computing position o a cell of an index : " << cell << std::endl;
783 unsigned dimension = 0;
784 for (std::size_t i = this->multipliers.size(); i != 0; --i) {
785 unsigned position = cell / this->multipliers[i - 1];
786
787 if (dbg) {
788 std::clog << "i-1 :" << i - 1 << std::endl;
789 std::clog << "cell : " << cell << std::endl;
790 std::clog << "position : " << position << std::endl;
791 std::clog << "multipliers[" << i - 1 << "] = " << this->multipliers[i - 1] << std::endl;
792 }
793
794 if (position % 2 == 1) {
795 if (dbg) std::clog << "Nonzero length in this direction \n";
796 dimension++;
797 }
798 cell = cell % this->multipliers[i - 1];
799 }
800 return dimension;
801}
802
803template <typename T>
805 return this->data[cell];
806}
807
808template <typename T>
810 bool dbg = false;
811
812 // this vector will be used to check which elements have already been taken care of in imposing lower star filtration
813 std::vector<bool> is_this_cell_considered(this->data.size(), false);
814
815 std::size_t size_to_reserve = 1;
816 for (std::size_t i = 0; i != this->multipliers.size(); ++i) {
817 size_to_reserve *= (std::size_t)((this->multipliers[i] - 1) / 2);
818 }
819
820 std::vector<std::size_t> indices_to_consider;
821 indices_to_consider.reserve(size_to_reserve);
822 // we assume here that we already have a filtration on the top dimensional cells and
823 // we have to extend it to lower ones.
825 for (it = this->top_dimensional_cells_iterator_begin(); it != this->top_dimensional_cells_iterator_end(); ++it) {
826 indices_to_consider.push_back(it.compute_index_in_bitmap());
827 }
828
829 while (indices_to_consider.size()) {
830 if (dbg) {
831 std::clog << "indices_to_consider in this iteration \n";
832 for (std::size_t i = 0; i != indices_to_consider.size(); ++i) {
833 std::clog << indices_to_consider[i] << " ";
834 }
835 }
836 std::vector<std::size_t> new_indices_to_consider;
837 for (std::size_t i = 0; i != indices_to_consider.size(); ++i) {
838 std::vector<std::size_t> bd = this->get_boundary_of_a_cell(indices_to_consider[i]);
839 for (std::size_t boundaryIt = 0; boundaryIt != bd.size(); ++boundaryIt) {
840 if (dbg) {
841 std::clog << "filtration of a cell : " << bd[boundaryIt] << " is : " << this->data[bd[boundaryIt]]
842 << " while of a cell: " << indices_to_consider[i] << " is: " << this->data[indices_to_consider[i]]
843 << std::endl;
844 }
845 if (this->data[bd[boundaryIt]] > this->data[indices_to_consider[i]]) {
846 this->data[bd[boundaryIt]] = this->data[indices_to_consider[i]];
847 if (dbg) {
848 std::clog << "Setting the value of a cell : " << bd[boundaryIt]
849 << " to : " << this->data[indices_to_consider[i]] << std::endl;
850 }
851 }
852 if (is_this_cell_considered[bd[boundaryIt]] == false) {
853 new_indices_to_consider.push_back(bd[boundaryIt]);
854 is_this_cell_considered[bd[boundaryIt]] = true;
855 }
856 }
857 }
858 indices_to_consider.swap(new_indices_to_consider);
859 }
860}
861
862template <typename T>
863bool compareFirstElementsOfTuples(const std::pair<std::pair<T, std::size_t>, char>& first,
864 const std::pair<std::pair<T, std::size_t>, char>& second) {
865 if (first.first.first < second.first.first) {
866 return true;
867 } else {
868 if (first.first.first > second.first.first) {
869 return false;
870 }
871 // in this case first.first.first == second.first.first, so we need to compare dimensions
872 return first.second < second.second;
873 }
874}
875
876} // namespace cubical_complex
877
878namespace Cubical_complex = cubical_complex;
879
880} // namespace Gudhi
881
882#endif // BITMAP_CUBICAL_COMPLEX_BASE_H_
Iterator through all cells in the complex (in order they appear in the structure – i....
Definition: Bitmap_cubical_complex_base.h:254
All_cells_range class provides ranges for All_cells_iterator.
Definition: Bitmap_cubical_complex_base.h:316
Iterator through top dimensional cells of the complex. The cells appear in order they are stored in t...
Definition: Bitmap_cubical_complex_base.h:358
Top_dimensional_cells_iterator_range class provides ranges for Top_dimensional_cells_iterator_range.
Definition: Bitmap_cubical_complex_base.h:456
Cubical complex represented as a bitmap, class with basic implementation.
Definition: Bitmap_cubical_complex_base.h:53
All_cells_iterator all_cells_iterator_end()
Definition: Bitmap_cubical_complex_base.h:307
std::vector< std::size_t >::const_iterator Coboundary_iterator
Definition: Bitmap_cubical_complex_base.h:345
Definition: Bitmap_cubical_complex_base.h:60
Definition: Bitmap_cubical_complex_base.h:527
Definition: Bitmap_cubical_complex_base.h:809
Definition: Bitmap_cubical_complex_base.h:212
All_cells_iterator all_cells_iterator_begin()
Definition: Bitmap_cubical_complex_base.h:299
virtual std::vector< std::size_t > get_coboundary_of_a_cell(std::size_t cell) const
Definition: Bitmap_cubical_complex_base.h:760
Definition: Bitmap_cubical_complex_base.h:780
Definition: Bitmap_cubical_complex_base.h:207
Top_dimensional_cells_iterator top_dimensional_cells_iterator_begin()
Definition: Bitmap_cubical_complex_base.h:436
friend std::ostream & operator<<(std::ostream &os, const Bitmap_cubical_complex_base< K > &b)
Definition: Bitmap_cubical_complex_base.h:574
virtual std::vector< std::size_t > get_boundary_of_a_cell(std::size_t cell) const
Definition: Bitmap_cubical_complex_base.h:733
Definition: Bitmap_cubical_complex_base.h:352
std::pair< T, T > min_max_filtration()
Definition: Bitmap_cubical_complex_base.h:564
Top_dimensional_cells_iterator top_dimensional_cells_iterator_end()
Definition: Bitmap_cubical_complex_base.h:444
std::vector< std::size_t >::const_iterator Boundary_iterator
Definition: Bitmap_cubical_complex_base.h:333
Definition: Bitmap_cubical_complex_base.h:618
T & get_cell_data(std::size_t cell)
Definition: Bitmap_cubical_complex_base.h:804
Definition: Bitmap_cubical_complex_base.h:340
Definition: Bitmap_cubical_complex_base.h:143
virtual ~Bitmap_cubical_complex_base()
Definition: Bitmap_cubical_complex_base.h:84
This is an implementation of a counter being a vector of integers.
Definition: counter.h:32
std::ostream & operator<<(std::ostream &os, const Permutahedral_representation< Vertex, OrderedSetPartition > &simplex)
Print a permutahedral representation to a stream.
Definition: Permutahedral_representation.h:173
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
