Gudhi::cubical_complex::Bitmap_cubical_complex_base< T >::Top_dimensional_cells_iterator Class Reference
Iterator through top dimensional cells of the complex. The cells appear in order they are stored in the structure (i.e. in lexicographical order) More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/Bitmap_cubical_complex_base.h>
Detailed Description
template<typename T>
class Gudhi::cubical_complex::Bitmap_cubical_complex_base< T >::Top_dimensional_cells_iterator
The documentation for this class was generated from the following file:
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:28 for GUDHI by Doxygen 1.9.2
