Handle type for the vertices of a cell complex.
More...
Must be a signed integer type. operator< defines a total order on it.
- Examples:
- Contraction/Garland_heckbert.cpp, Persistent_cohomology/plain_homology.cpp, Persistent_cohomology/rips_persistence_step_by_step.cpp, Simplex_tree/cech_complex_cgal_mini_sphere_3d.cpp, Simplex_tree/example_alpha_shapes_3_simplex_tree_from_off_file.cpp, Simplex_tree/mini_simplex_tree.cpp, Simplex_tree/simple_simplex_tree.cpp, Simplex_tree/simplex_tree_from_cliques_of_graph.cpp, Skeleton_blocker/Skeleton_blocker_from_simplices.cpp, Skeleton_blocker/Skeleton_blocker_iteration.cpp, and Skeleton_blocker/Skeleton_blocker_link.cpp.
The documentation for this struct was generated from the following file:
