Type returned by Tangential_complex::fix_inconsistencies_using_perturbation
More...
Public Attributes | |
bool | success = false |
true if all inconsistencies could be removed, false if the time limit has been reached before | |
unsigned int | num_steps = 0 |
number of steps performed | |
std::size_t | initial_num_inconsistent_stars = 0 |
initial number of inconsistent stars | |
std::size_t | best_num_inconsistent_stars = 0 |
best number of inconsistent stars during the process | |
std::size_t | final_num_inconsistent_stars = 0 |
final number of inconsistent stars | |
GUDHI Version 3.4.1 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Fri Jan 22 2021 09:41:16 for GUDHI by Doxygen 1.8.13 |
