Graph simplicial complex methods.
More...
Go to the source code of this file.
| template<typename SimplicialComplexForProximityGraph > |
| using | Gudhi::Proximity_graph = typename boost::adjacency_list< boost::vecS, boost::vecS, boost::directedS, boost::property< vertex_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value >, boost::property< edge_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value > > |
| | Proximity_graph contains the vertices and edges with their filtration values in order to store the result of Gudhi::compute_proximity_graph function. More...
| template<typename SimplicialComplexForProximityGraph , typename ForwardPointRange , typename Distance > |
| Proximity_graph< SimplicialComplexForProximityGraph > | Gudhi::compute_proximity_graph (const ForwardPointRange &points, typename SimplicialComplexForProximityGraph::Filtration_value threshold, Distance distance) |
| | Computes the proximity graph of the points. More...
◆ Proximity_graph
| using Gudhi::Proximity_graph = typedef typename boost::adjacency_list < boost::vecS, boost::vecS, boost::directedS , boost::property < vertex_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value > , boost::property < edge_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value > > |
- Template Parameters
| SimplicialComplexForProximityGraph | furnishes Filtration_value type definition. |
◆ compute_proximity_graph()
| Proximity_graph<SimplicialComplexForProximityGraph> Gudhi::compute_proximity_graph |
const ForwardPointRange & |
points, |
typename SimplicialComplexForProximityGraph::Filtration_value |
threshold, |
Distance |
distance |
If points contains n elements, the proximity graph is the graph with n vertices, and an edge [u,v] iff the distance function between points u and v is smaller than threshold.
| SimplicialComplexForProximityGraph | furnishes Filtration_value and Vertex_handle type definitions. |
| ForwardPointRange | furnishes .begin() and .end() methods. |
| Distance | furnishes operator()(const Point& p1, const Point& p2), where Point is a point from the ForwardPointRange, and that returns a Filtration_value. |
- Examples:
- Simplex_tree/cech_complex_cgal_mini_sphere_3d.cpp.
