Vertex that stores a point. More...
Public Member Functions | |
Point & | point () |
Access to the point. | |
const Point & | point () |
Public Member Functions inherited from Gudhi::skeleton_blocker::SkeletonBlockerDS::Graph_vertex | |
void | deactivate () |
Used to deactivate a vertex for example when contracting an edge. It allows in some cases to remove the vertex at low cost. | |
void | activate () |
Used to activate a vertex. | |
bool | is_active () const |
Tells if the vertex is active. | |
GUDHI Version 3.4.1 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Fri Jan 22 2021 09:41:16 for GUDHI by Doxygen 1.8.13 |
