11 #ifndef SPARSE_RIPS_COMPLEX_H_ 12 #define SPARSE_RIPS_COMPLEX_H_ 14 #include <gudhi/Debug_utils.h> 16 #include <gudhi/choose_n_farthest_points.h> 18 #include <boost/graph/adjacency_list.hpp> 19 #include <boost/range/metafunctions.hpp> 25 namespace rips_complex {
44 template <
typename Filtration_value>
48 typedef typename boost::adjacency_list<boost::vecS, boost::vecS, boost::directedS,
49 boost::property<vertex_filtration_t, Filtration_value>,
50 boost::property<edge_filtration_t, Filtration_value>>
53 typedef int Vertex_handle;
65 template <
typename RandomAccessPo
intRange,
typename Distance>
68 GUDHI_CHECK(epsilon > 0,
"epsilon must be positive");
69 auto dist_fun = [&](Vertex_handle i, Vertex_handle j) {
return distance(points[i], points[j]); };
71 std::back_inserter(sorted_points), std::back_inserter(params));
72 compute_sparse_graph(dist_fun, epsilon, mini, maxi);
85 template <
typename DistanceMatrix>
88 [&](Vertex_handle i, Vertex_handle j) {
return (i==j) ? 0 : (i<j) ? distance_matrix[j][i] : distance_matrix[i][j]; },
89 epsilon, mini, maxi) {}
101 template <
typename SimplicialComplexForRips>
104 std::invalid_argument(
"Sparse_rips_complex::create_complex - simplicial complex is not empty"));
111 const int n = boost::size(params);
112 std::vector<Filtration_value> lambda(n);
115 lambda[sorted_points[i]] = params[i];
116 double cst = epsilon_ * (1 - epsilon_) / 2;
118 auto filt = complex.filtration(sh);
119 auto mini = filt * cst;
120 for(
auto v : complex.simplex_vertex_range(sh)){
126 complex.expansion_with_blockers(dim_max, block);
131 template <
typename Distance>
133 const auto& points = sorted_points;
134 const int n = boost::size(points);
135 double cst = epsilon * (1 - epsilon) / 2;
137 new (&graph_) Graph(n);
139 typename boost::graph_traits<Graph>::vertex_iterator v_i, v_e;
140 for (std::tie(v_i, v_e) = vertices(graph_); v_i != v_e; ++v_i) {
143 put(vertex_filtration_t(), graph_, v, 0);
149 for (
int i = 0; i < n; ++i) {
150 auto&& pi = points[i];
152 if (li < mini)
break;
153 for (
int j = i + 1; j < n; ++j) {
154 auto&& pj = points[j];
155 auto d = dist(pi, pj);
157 if (lj < mini)
break;
158 GUDHI_CHECK(lj <= li,
"Bad furthest point sorting");
162 if (d * epsilon <= 2 * lj)
164 else if (d * epsilon > li + lj)
167 alpha = (d - lj / epsilon) * 2;
169 if (epsilon < 1 && alpha * cst > lj)
174 add_edge(pi, pj, alpha, graph_);
183 std::vector<Vertex_handle> sorted_points;
185 std::vector<Filtration_value> params;
192 #endif // SPARSE_RIPS_COMPLEX_H_ void expansion(int max_dim)
Expands the simplicial complex containing only its one skeleton until a given maximal dimension as ex...
void insert_graph(const OneSkeletonGraph &skel_graph)
Inserts a given Gudhi::rips_complex::Rips_complex::OneSkeletonGraph in the simplicial complex...
void choose_n_farthest_points(Distance dist, Point_range const &input_pts, std::size_t final_size, std::size_t starting_point, PointOutputIterator output_it, DistanceOutputIterator dist_it={})
Subsample by a greedy strategy of iteratively adding the farthest point from the current chosen point...
Definition: choose_n_farthest_points.h:69
The concept SimplicialComplexForRips describes the requirements for a type to implement a simplicial ...
Definition: SimplicialComplexForRips.h:21
Definition: SimplicialComplexForAlpha.h:14
Sparse_rips_complex(const DistanceMatrix &distance_matrix, double epsilon, Filtration_value mini=-std::numeric_limits< Filtration_value >::infinity(), Filtration_value maxi=std::numeric_limits< Filtration_value >::infinity())
Sparse_rips_complex constructor from a distance matrix.
Definition: Sparse_rips_complex.h:86
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
Sparse_rips_complex(const RandomAccessPointRange &points, Distance distance, double epsilon, Filtration_value mini=-std::numeric_limits< Filtration_value >::infinity(), Filtration_value maxi=std::numeric_limits< Filtration_value >::infinity())
Sparse_rips_complex constructor from a list of points.
Definition: Sparse_rips_complex.h:66
std::size_t num_vertices()
Returns the number of vertices in the simplicial complex.
unspecified Simplex_handle
Handle type to a simplex contained in the simplicial complex.
Definition: SimplicialComplexForRips.h:26
Sparse Rips complex data structure.
Definition: Sparse_rips_complex.h:45
Graph simplicial complex methods.
void create_complex(SimplicialComplexForRips &complex, int dim_max)
Fills the simplicial complex with the sparse Rips graph and expands it with all the cliques...
Definition: Sparse_rips_complex.h:102
