Gudhi::alpha_complex::SimplicialComplexForAlpha3d Struct Reference
The concept SimplicialComplexForAlpha3d describes the requirements for a type to implement a simplicial complex, that can be created from a Alpha_complex_3d. More...
Public Types
typedef unspecified Vertex_handle
typedef unspecified Filtration_value
Public Member Functions
std::size_t num_vertices ()
void insert_simplex (std::vector< Vertex_handle > const &vertex_range, Filtration_value filtration)
 Inserts a simplex from a given simplex (represented by a vector of Vertex_handle) in the simplicial complex with the given 'filtration' value.
void make_filtration_non_decreasing ()
void prune_above_filtration (Filtration_value filtration)
Detailed Description
Member Typedef Documentation
◆ Filtration_value
Handle to specify the simplex filtration value.
◆ Vertex_handle
Handle to specify a vertex. Must be a non-negative integer.
Member Function Documentation
◆ make_filtration_non_decreasing()
void Gudhi::alpha_complex::SimplicialComplexForAlpha3d::make_filtration_non_decreasing ( )
Browses the simplicial complex to make the filtration non-decreasing.
◆ num_vertices()
std::size_t Gudhi::alpha_complex::SimplicialComplexForAlpha3d::num_vertices ( )
Returns the number of vertices in the simplicial complex.
◆ prune_above_filtration()
void Gudhi::alpha_complex::SimplicialComplexForAlpha3d::prune_above_filtration ( Filtration_value  filtration)
Prune the simplicial complex above 'filtration' value given as parameter.
The documentation for this struct was generated from the following file:
GUDHI  Version 3.4.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Dec 15 2020 16:00:41 for GUDHI by Doxygen 1.8.13
