The concept Real_valued_topological_data describes the requirements for a type to implement a container that allows computations of its projections to R. More...
Public Member Functions | |
| size_t | number_of_projections_to_R () |
| double | project_to_R (size_t number_of_projection) |
| size_t Gudhi::Persistence_representations::Real_valued_topological_data::number_of_projections_to_R | ( | ) |
Typically there are various ways data can be projected to R. This function gives us the number of functions for vectorization provided by a given class.
| double Gudhi::Persistence_representations::Real_valued_topological_data::project_to_R | ( | size_t | number_of_projection | ) |
This is a function to compute the projection from this container to reals. The parameter of a function have to be between 0 and the value returned by number_of_projections_to_R().
| GUDHI Version 3.4.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Tue Dec 15 2020 16:00:42 for GUDHI by Doxygen 1.8.13 |
