Loading [MathJax]/extensions/tex2jax.js
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::witness_complex::Euclidean_witness_complex< Kernel_ > Class Template Reference
Constructs (weak) witness complex for given sets of witnesses and landmarks in Euclidean space. More...
Public Member Functions
template<typename LandmarkRange , typename WitnessRange >
 Euclidean_witness_complex (const LandmarkRange &landmarks, const WitnessRange &witnesses)
 Initializes member variables before constructing simplicial complex. More...
Point_d get_point (Vertex_handle vertex) const
 Returns the point corresponding to the given vertex. More...
- Public Member Functions inherited from Gudhi::witness_complex::Witness_complex< std::vector< Gudhi::spatial_searching::Kd_tree_search< Kernel_, std::vector< Kernel_::Point_d > >::INS_range > >
 Witness_complex (std::vector< Gudhi::spatial_searching::Kd_tree_search< Kernel_, std::vector< Kernel_::Point_d > >::INS_range > const &nearest_landmark_table)
bool create_complex (SimplicialComplexForWitness &complex, double max_alpha_square, std::size_t limit_dimension=std::numeric_limits< std::size_t >::max()) const
 Outputs the (weak) witness complex of relaxation 'max_alpha_square' in a simplicial complex data structure. More...
Detailed Description
template<class Kernel_>
class Gudhi::witness_complex::Euclidean_witness_complex< Kernel_ >
Template Parameters
Kernel_requires a CGAL::Epick_d class.
Examples:
Witness_complex/example_nearest_landmark_table.cpp, Witness_complex/example_strong_witness_complex_off.cpp, Witness_complex/example_witness_complex_off.cpp, Witness_complex/example_witness_complex_sphere.cpp, and Witness_complex/weak_witness_persistence.cpp.
Constructor & Destructor Documentation
◆ Euclidean_witness_complex()
template<class Kernel_ >
Gudhi::witness_complex::Euclidean_witness_complex< Kernel_ >::Euclidean_witness_complex ( const LandmarkRange &  landmarks,
const WitnessRange &  witnesses
inline
Records landmarks from the range 'landmarks' into a table internally, as well as witnesses from the range 'witnesses'. Both ranges should have value_type Kernel_::Point_d.
Member Function Documentation
◆ get_point()
Point_d Gudhi::witness_complex::Euclidean_witness_complex< Kernel_ >::get_point ( Vertex_handle  vertex) const
inline
Parameters
[in]vertexVertex handle of the point to retrieve.
The documentation for this class was generated from the following file:
GUDHI  Version 3.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Aug 11 2020 11:09:14 for GUDHI by Doxygen 1.8.13
