Cech complex data structure. More...
Public Member Functions | |
| Cech_complex (const ForwardPointRange &points, Filtration_value max_radius) | |
| Cech_complex constructor from a list of points. More... | |
| template<typename SimplicialComplexForCechComplex > | |
| void | create_complex (SimplicialComplexForCechComplex &complex, int dim_max) |
| Initializes the simplicial complex from the proximity graph and expands it until a given maximal dimension, using the Cech blocker oracle. More... | |
| Filtration_value | max_radius () const |
| const Point & | get_point (Vertex_handle vertex) const |
The data structure is a proximity graph, containing edges when the edge length is less or equal to a given max_radius. Edge length is computed from Gudhi::Minimal_enclosing_ball_radius distance function.
| SimplicialComplexForProximityGraph | furnishes Vertex_handle and Filtration_value type definition required by Gudhi::Proximity_graph. |
| ForwardPointRange | must be a range for which std::begin() and std::end() methods return input iterators on a point. std::begin() and std::end() methods are also required for a point. |
inline |
| [in] | points | Range of points. |
| [in] | max_radius | Maximal radius value. |
| ForwardPointRange | must be a range of Point. Point must be a range of copyable Cartesian coordinates. |
inline |
| [in] | complex | SimplicialComplexForCech to be created. |
| [in] | dim_max | graph expansion until this given maximal dimension. |
| std::invalid_argument | In debug mode, if complex.num_vertices() does not return 0. |
inline |
| [in] | vertex | Point position in the range. |
inline |
| GUDHI Version 3.3.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Tue Aug 11 2020 11:09:13 for GUDHI by Doxygen 1.8.13 |
