Concept describing the requirements for a class to compute persistent homology. More...
Public Types | |
| typedef unspecified | Filtered_complex |
| Type of filtered cell complex on which persistent homology is computed. More... | |
| typedef unspecified | Coefficient_field |
| Type of coefficients to be used for computing persistent homology. More... | |
| typedef unspecified PersistentHomology::Coefficient_field |
Must be a model of concept CoefficientField.
| typedef unspecified PersistentHomology::Filtered_complex |
Must be a model of concept FilteredComplex.
| GUDHI Version 3.2.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Wed May 20 2020 07:53:47 for GUDHI by Doxygen 1.8.13 |
