Gudhi::skeleton_blocker::Skeleton_blocker_off_reader< Complex > Class Template Reference
Class that allows to load a Skeleton_blocker_complex from an off file. More...
Public Member Functions
 Skeleton_blocker_off_reader (const std::string &name_file, Complex &read_complex, bool read_only_points=false, bool is_flag=false)
bool is_valid () const
Detailed Description
template<typename Complex>
class Gudhi::skeleton_blocker::Skeleton_blocker_off_reader< Complex >
Examples:
Contraction/Garland_heckbert.cpp, and Contraction/Rips_contraction.cpp.
Constructor & Destructor Documentation
◆ Skeleton_blocker_off_reader()
Gudhi::skeleton_blocker::Skeleton_blocker_off_reader< Complex >::Skeleton_blocker_off_reader ( const std::string &  name_file,
Complex &  read_complex,
bool  read_only_points = false,
bool  is_flag = false
inline
name_file : file to read read_complex : complex that will receive the file content read_only_points : specify true if only the points must be read
Member Function Documentation
◆ is_valid()
bool Gudhi::skeleton_blocker::Skeleton_blocker_off_reader< Complex >::is_valid ( ) const
inline
return true if reading did not meet problems.
The documentation for this class was generated from the following file:
GUDHI  Version 3.2.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Wed May 20 2020 07:53:47 for GUDHI by Doxygen 1.8.13
