Structure representing coefficients in a set of finite fields simultaneously using the chinese remainder theorem.
More...
Details on the algorithms may be found in [6]
- Examples:
- Persistent_cohomology/rips_multifield_persistence.cpp.
◆ inverse()
| std::pair<Element, Element> Gudhi::persistent_cohomology::Multi_field::inverse |
Element |
x, |
Element |
QS |
inline |
Returns the inverse in the field. Modifies P. ???
◆ plus_times_equal()
| Element Gudhi::persistent_cohomology::Multi_field::plus_times_equal |
const Element & |
x, |
const Element & |
y, |
const Element & |
w |
inline |
◆ times()
| Element Gudhi::persistent_cohomology::Multi_field::times |
const Element & |
y, |
const Element & |
w |
inline |
◆ times_minus()
| Element Gudhi::persistent_cohomology::Multi_field::times_minus |
const Element & |
x, |
const Element & |
y |
inline |
The documentation for this class was generated from the following file:
