Searching...
No Matches
Zp_field_element< characteristic, Unsigned_integer_type, class > Class Template Reference
Class representing an element of the \( \mathbb{F}_p \) field for any prime number \( p \). More...
#include <gudhi/Fields/Zp_field.h>
Public Types
using Element = Unsigned_integer_type
using Characteristic = Element
Public Member Functions
 Zp_field_element ()
 Default constructor. Sets the element to 0.
template<typename Integer_type, class = isInteger<Integer_type>>
 Zp_field_element (Integer_type element)
 Constructor setting the element to the given value.
 Zp_field_element (const Zp_field_element &toCopy)=default
 Copy constructor.
 Zp_field_element (Zp_field_element &&toMove) noexcept
 Move constructor.
Zp_field_element & operator= (Zp_field_element other)
 Assign operator.
Zp_field_element & operator= (Zp_field_element &&other) noexcept
 Move assign operator.
Zp_field_element & operator= (const Integer_type &value)
 Assign operator.
 operator unsigned int () const
 Casts the element into an unsigned int.
Zp_field_element get_inverse () const
 Returns the inverse of the element in the field.
std::pair< Zp_field_element, unsigned int > get_partial_inverse (unsigned int productOfCharacteristics) const
 For interface purposes with multi-fields. Returns the inverse together with the argument.
Element get_value () const
 Returns the value of the element.
Static Public Member Functions
static Zp_field_element get_additive_identity ()
 Returns the additive identity of the field.
static Zp_field_element get_multiplicative_identity ()
 Returns the multiplicative identity of the field.
static Zp_field_element get_partial_multiplicative_identity (unsigned int productOfCharacteristics)
 For interface purposes with multi-fields. Returns the multiplicative identity of the field.
static constexpr unsigned int get_characteristic ()
 Returns the current characteristic.
Friends
void operator+= (Zp_field_element &f1, const Zp_field_element &f2)
 operator+=
void operator+= (Zp_field_element &f, const Integer_type &v)
 operator+=
Zp_field_element operator+ (Zp_field_element f1, const Zp_field_element &f2)
 operator+
Zp_field_element operator+ (Zp_field_element f, const Integer_type &v)
 operator+
Integer_type operator+ (const Integer_type &v, Zp_field_element f)
 operator+
void operator-= (Zp_field_element &f1, const Zp_field_element &f2)
 operator-=
void operator-= (Zp_field_element &f, const Integer_type &v)
 operator-=
Zp_field_element operator- (Zp_field_element f1, const Zp_field_element &f2)
 operator-
Zp_field_element operator- (Zp_field_element f, const Integer_type &v)
 operator-
Integer_type operator- (const Integer_type &v, const Zp_field_element &f)
 operator-
void operator*= (Zp_field_element &f1, const Zp_field_element &f2)
 operator*=
void operator*= (Zp_field_element &f, const Integer_type &v)
 operator*=
Zp_field_element operator* (Zp_field_element f1, const Zp_field_element &f2)
 operator*
Zp_field_element operator* (Zp_field_element f, const Integer_type &v)
 operator*
Integer_type operator* (const Integer_type &v, Zp_field_element f)
 operator*
bool operator== (const Zp_field_element &f1, const Zp_field_element &f2)
 operator==
bool operator== (const Integer_type &v, const Zp_field_element &f)
 operator==
bool operator== (const Zp_field_element &f, const Integer_type &v)
 operator==
bool operator!= (const Zp_field_element &f1, const Zp_field_element &f2)
 operator!=
bool operator!= (const Integer_type &v, const Zp_field_element &f)
 operator!=
bool operator!= (const Zp_field_element &f, const Integer_type &v)
 operator!=
void swap (Zp_field_element &f1, Zp_field_element &f2) noexcept
 Swap operator.
Detailed Description
template<unsigned int characteristic, typename Unsigned_integer_type = unsigned int, class = std::enable_if_t<std::is_unsigned_v<Unsigned_integer_type> >>
class Zp_field_element< characteristic, Unsigned_integer_type, class >
Template Parameters
characteristicValue of the characteristic of the field. Has to be a positive prime number.
Unsigned_integer_typeA native unsigned integer type: unsigned int, long unsigned int, etc. Will be used as the field element type.
Member Typedef Documentation
◆ Characteristic
using Gudhi::persistence_fields::Zp_field_element< characteristic, Unsigned_integer_type, class >::Characteristic = Element
Type for the field characteristic.
◆ Element
using Gudhi::persistence_fields::Zp_field_element< characteristic, Unsigned_integer_type, class >::Element = Unsigned_integer_type
Type for the elements in the field.
Constructor & Destructor Documentation
◆ Zp_field_element() [1/3]
Gudhi::persistence_fields::Zp_field_element< characteristic, Unsigned_integer_type, class >::Zp_field_element ( Integer_type element)
inline
Template Parameters
Integer_typeA native integer type. Should be able to contain the characteristic if signed.
Parameters
elementValue of the element.
◆ Zp_field_element() [2/3]
Gudhi::persistence_fields::Zp_field_element< characteristic, Unsigned_integer_type, class >::Zp_field_element ( const Zp_field_element< characteristic, Unsigned_integer_type, class > & toCopy)
default
Copy constructor.
Parameters
toCopyElement to copy.
◆ Zp_field_element() [3/3]
Gudhi::persistence_fields::Zp_field_element< characteristic, Unsigned_integer_type, class >::Zp_field_element ( Zp_field_element< characteristic, Unsigned_integer_type, class > && toMove)
inlinenoexcept
Move constructor.
Parameters
toMoveElement to move.
Member Function Documentation
◆ get_additive_identity()
static Zp_field_element Gudhi::persistence_fields::Zp_field_element< characteristic, Unsigned_integer_type, class >::get_additive_identity ( )
inlinestatic
Returns
0.
◆ get_characteristic()
static constexpr unsigned int Gudhi::persistence_fields::Zp_field_element< characteristic, Unsigned_integer_type, class >::get_characteristic ( )
inlinestaticconstexpr
Returns
The value of the current characteristic.
◆ get_inverse()
Zp_field_element Gudhi::persistence_fields::Zp_field_element< characteristic, Unsigned_integer_type, class >::get_inverse ( ) const
inline
Returns
The inverse.
◆ get_multiplicative_identity()
static Zp_field_element Gudhi::persistence_fields::Zp_field_element< characteristic, Unsigned_integer_type, class >::get_multiplicative_identity ( )
inlinestatic
Returns
1.
◆ get_partial_inverse()
std::pair< Zp_field_element, unsigned int > Gudhi::persistence_fields::Zp_field_element< characteristic, Unsigned_integer_type, class >::get_partial_inverse ( unsigned int productOfCharacteristics) const
inline
Parameters
productOfCharacteristicsSome value.
Returns
Pair whose first element is the inverse and the second element is productOfCharacteristics.
◆ get_partial_multiplicative_identity()
static Zp_field_element Gudhi::persistence_fields::Zp_field_element< characteristic, Unsigned_integer_type, class >::get_partial_multiplicative_identity ( unsigned int productOfCharacteristics)
inlinestatic
Parameters
Returns
1.
◆ get_value()
Element Gudhi::persistence_fields::Zp_field_element< characteristic, Unsigned_integer_type, class >::get_value ( ) const
inline
Returns
◆ operator=()
Zp_field_element & Gudhi::persistence_fields::Zp_field_element< characteristic, Unsigned_integer_type, class >::operator= ( const Integer_type & value)
inline
Assign operator.
Template Parameters
Friends And Related Symbol Documentation
◆ operator!= [1/2]
bool operator!= ( const Integer_type & v,
const Zp_field_element< characteristic, Unsigned_integer_type, class > & f )
friend
operator!=
Template Parameters
◆ operator!= [2/2]
bool operator!= ( const Zp_field_element< characteristic, Unsigned_integer_type, class > & f,
const Integer_type & v )
friend
operator!=
Template Parameters
◆ operator* [1/2]
Integer_type operator* ( const Integer_type & v,
Zp_field_element< characteristic, Unsigned_integer_type, class > f )
friend
operator*
Template Parameters
◆ operator* [2/2]
Zp_field_element operator* ( Zp_field_element< characteristic, Unsigned_integer_type, class > f,
friend
operator*
Template Parameters
◆ operator+ [1/2]
Integer_type operator+ ( const Integer_type & v,
friend
operator+
Template Parameters
◆ operator+ [2/2]
Zp_field_element operator+ ( Zp_field_element< characteristic, Unsigned_integer_type, class > f,
friend
operator+
Template Parameters
◆ operator- [1/2]
Integer_type operator- ( const Integer_type & v,
friend
operator-
Template Parameters
◆ operator- [2/2]
Zp_field_element operator- ( Zp_field_element< characteristic, Unsigned_integer_type, class > f,
friend
operator-
Template Parameters
◆ operator== [1/2]
bool operator== ( const Integer_type & v,
friend
operator==
Template Parameters
◆ operator== [2/2]
bool operator== ( const Zp_field_element< characteristic, Unsigned_integer_type, class > & f,
friend
operator==
Template Parameters
The documentation for this class was generated from the following file:
