unordered_set_column.h File Reference
Contains the Gudhi::persistence_matrix::Unordered_set_column class. Also defines the std::hash method for Gudhi::persistence_matrix::Unordered_set_column. More...
Go to the source code of this file.
Classes
class  Gudhi::persistence_matrix::Unordered_set_column< Master_matrix >
 Column class following the PersistenceMatrixColumn concept. More...
struct  std::hash< Gudhi::persistence_matrix::Unordered_set_column< Master_matrix > >
 Hash method for Gudhi::persistence_matrix::Unordered_set_column. More...
Namespaces
namespace  Gudhi
 Gudhi namespace.
namespace  Gudhi::persistence_matrix
 Persistence matrix namespace.
Detailed Description
Author
Hannah Schreiber
