Column class following the PersistenceMatrixColumn concept. More...
#include <gudhi/Persistence_matrix/columns/unordered_set_column.h>
Column based on an unordered set structure. The entries are not ordered, but only non-zero values are stored uniquely in the underlying container. When adding an entry range into it, the given entry range also does not need to be ordered (contrary to most other column types).
| Master_matrix | An instantiation of Matrix from which all types and options are deduced. |
