All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::zigzag_persistence::FilteredZigzagOptions Struct Reference
List of options used for the filtered zigzag persistence computation. More...
#include <concept/Zigzag_persistence/ZigzagOptions.h>
Public Types
using Internal_key = unspecified
 Numerical type for the cell IDs used internally and other indexations. It must be signed.
using Cell_key = unspecified
 Type for the cell IDs used at insertion and in the boundaries given as argument. Has to be usable as key in a hashtable, so "hashable" and comparable.
using Filtration_value = unspecified
 Type for filtration values.
using Dimension = unspecified
 Type for the dimension values.
Static Public Attributes
static const Gudhi::persistence_matrix::Column_types column_type
 Column type used by the internal matrix.
Detailed Description
The documentation for this struct was generated from the following file:
